Going with Nitto DR's for rear...what should go up front?
Originally Posted by Zepher
I ran with 315 nittos on my friends car and it wasn't that fun. these were on stock 9" SS ZR1 wheels on his 99 HOSS. *** end was really loose, especially when shifting hard and just felt very unstable at 30psi on the street and 18psi.at the track.
Now, my brother has the 315 BFG G-Force KD's on his 17x9.5" Z06 wheels and they feel pretty much normal. he runs 35psi in the KD's.
i'd just run stock size up front, 275/40/17 and whatever you feel comfortable putting on the rear,
So what would be best then given a 10" wheel on the front?
Originally Posted by Trust
555R's are a good choice, just no in a 315 for a stock width wheel.
EDIT: I just looked on DTD and it appears there is no NT555 in that size...and it shows the widest for a 17" wheel is a 285? Say it ain't so
Originally Posted by BlackHawk T/A
Alright good stuff, I looked up the RII and found this on Nitto's site:
[/b]
Any comments on that last sentence? Do they really ride much rougher than street tires?
[/b]
Good point on the weather. In Cleveland below 55 degrees, the Nittos are useless. Spin city through the first 3 gears. And yes the sidewall is stiffer on the RII but awesome at autox. Unless you have the budget for 8 tires and rims ( as most of us don't ) it's always a compromise.
http://www.autocross.us/forums/index.php?showtopic=1417
check out the amount of tires and wheels this member has accumulated.
btw,
you can find deals on factory/oem repros for dirt cheap if you just look around.
I bought my 555RII's with AFS ZR1's for $830 shipped, had one auto-x seesion on them.
I then found a pair of silver ZR1's that matched my first set for $50, and a pair of Chrome ZR1's with nearly new tires on them for $200. and then I picked up a pair of Nitto 555's for $160 which were slightly used but looked very very new.
Now I am in the process of trying to find a pair of silver ZR1's to replace the chrome ones as I am not too fond of really shiney wheels.
Also, the RII's suck in the cold as well (just like the DR's I assume), very slick when they are cold, but after a few miles they feel normal.
I got the NT555's to match the 555r's out back and they look great together. The NT's are actually wider than the 555r's, but the R's do run a little narrower. Off hand do you guys know if you can plug a nitto 555r safely? If you get a nail, or screw in it . ....
I run Nitto 555rII's all around, pulled 1.004g on the skid pad with my suspension setup. They're actually less of a rough ride than my Firestone Firehawk radials, most likely because of the softer tread... 6k on them and still plenty of tread left.
