265/40/17 with a 58mm offset
Old Mar 20, 2006 | 05:07 PM
2000NavyZ's Avatar
Default 265/40/17 with a 58mm offset
I tried searching and did not find anything....
Will a 265/40/17 with a 58 mm offset rim fit on the front without rubbing anything?
Old Mar 21, 2006 | 08:07 AM
Xsta Z 28's Avatar
What size wheel? 58 is a pretty big offset, and those tires are tiny.
Old Mar 21, 2006 | 05:31 PM
2000NavyZ's Avatar
so will they fit or not?
Old Mar 21, 2006 | 10:34 PM
Xsta Z 28's Avatar
I ask again what sized wheel?? Without telling the the wheel size the info you give me so far is usless . . . .
Old Mar 22, 2006 | 04:48 PM
2000NavyZ's Avatar
it is a 17 by 8.5 inch 58mm offset rim with a 265/40/17 tire.
Not to be an *** but, doesnt the 17 in my tire discription somewhat give away the rim size?
Old Mar 22, 2006 | 04:53 PM
Chris@DTD's Avatar
Closed ex-Sponsor Account
No, in no way does it advertise the width of the wheel.
It could be anywhere from a 17x7 to a 17x11. Pretty easy guess, right?
Old Mar 22, 2006 | 05:01 PM
Xsta Z 28's Avatar
Diameter tells me absolutely nothing . . . the width of the wheel is everything when you tell me an offset . . .
So to your question wil a 58 mm offset 8.5" wide wheel fit . . . yes, but the appearnce will not be ideal. It will be too deep into the wheel well.
Old Mar 22, 2006 | 05:31 PM
2000NavyZ's Avatar
sorry i did not think about the width while i was posting, so i shouldnt have any issues with the tire rubbing the inner fender well when the wheel is turned all the way in one direction. Sorry for all of the questions, they keep coming up as i go... Thanks alot for the help and being patient
