DTD heat cycling
Old Mar 27, 2006 | 07:11 PM
BackinBlack02SS's Avatar
Default DTD heat cycling
Anyone had their Nitto 555R's heat cycled from Discount Tire Direct before? Is it worth it?
Old Mar 27, 2006 | 08:21 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
https://ls1tech.com/forums/showthrea...ght=heat+cycle
Old Mar 27, 2006 | 08:22 PM
Z28/2002's Avatar
These are the two threads I found
Old Mar 27, 2006 | 08:28 PM
I read those too, but they don't exactly give very much info.
Old Mar 27, 2006 | 09:58 PM
Z28/2002's Avatar
After I put mine on I just drove around for about an hour and a half. Didn't spin them or anything. They worked pretty damn good at the track so I guess they are fine without the heat cycling
Old Mar 27, 2006 | 10:10 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
If its recommended by the manufacturer just go ahead and do it. It only adds about 30.00 to the price tag.
Old Mar 27, 2006 | 11:04 PM
Does Nitto recommend it for the 555R's?
Old Mar 7, 2007 | 07:41 AM
mondi2002's Avatar
Yes,
http://www.discounttiredirect.com/di...eatCycling.jsp
Leading tire manufacturers including BFGoodrich, Kumho, Nitto and Yokohama offer competition type tires that qualify as DOT legal for street use. Autocrossing, race days, driving schools and other racing venues demand this category of tire for maximum performance. But like any high performance part, these tires require careful break-in to achieve the full benefit of their construction.
A competition tire is built with a highly sophisticated tread compound, capable of sustaining traction throughout a much wider temperature range, but also extremely sensitive to the first heat cycle of its use. During this cycle, if controlled precisely, the tread compound stretches as it heats, breaking the weaker, shorter molecular bonds within the rubber. The benefit of this process is a tread compound that lasts longer and provides better traction. However, if the first cycle is not performed correctly, the tread may develop irregular compounding, leading to poor wear and inconsistent traction.
In the past, many racers tried to “heat cycle” their own tires with mixed results. Besides the inconsistency, there was the inconvenience of mounting and dismounting the tires before using them to race (after the first heat cycle, a competition tire must be rested 24 to 48 hours to reform the molecular bonds). In response to customer requests, Discount Tire Direct now offers heat cycling service.
The Discount Tire heat cycling system ensures consistent results by maintaining key conditions during the process: vertical scrubbing and “soft” temperature curve. Using rollers of proprietary design and placement, the system generates uniform heating and temperature build up throughout the tread (a condition not achievable on a vehicle due to camber) by rolling the tire and exerting vertical scrubbing force only. No lateral force is applied. A soft temperature curve, where the tire is gradually heated and then cooled over a specified time (ambient temperature must be consistent as well), is maintained and monitored during the cycle. In this way the entire tread is heat cycled uniformly throughout its depth and width.
At completion, the tire receives a Discount Tire Heat Cycle stamp. This service costs $15 per tire. All competition tire manufacturers recommend heat cycling service. In the time it takes to freight the tires, they have “rested” long enough to be race ready.
