Which fronts tires to use?
Old May 12, 2006 | 09:30 PM
LS1SpeedAddict's Avatar
Default Which front tires to use?
I just got my 3.5" bogarts for the front. Any suggestions as to which tires to use?
Old May 13, 2006 | 06:51 PM
Nobody has a recommendation?
Old May 13, 2006 | 09:04 PM
SJM Manufacturing Inc's Avatar
MTT-1573 if you want DOT legal tires. Any of the drag runners if you want the lightest setup i.e. MT ET Drag or Moroso DS2's.
Do NOT use VW tires or said radial front runners etc...
Old May 13, 2006 | 09:55 PM
Really why is that? It was already suggested to my to use VW tires.
Old May 14, 2006 | 01:29 AM
Krab's Avatar
The reason not to use the VW tires is because they're not speed, nor load rated for our cars. They are also supposed to set off the low trac light because of the diameter difference between the rear and front tires. Suprisingly enough though, many f-body owners are using these tires without problems. I'm running MT Sportman fronts (for peace of mind) on mine (the ones Steve just recommended) and haven't had any problems with my car at 120 mph.
The Sportman fronts cost ~$100 a tire while the VW's are ~$40 a tire.
Old May 14, 2006 | 01:59 AM
Strahley's Avatar
I use Kuhmo 165s on my fronts, and I have not run into any issues. I've seen 120+ mph several times on them, and have cruised at 70mph for a couple hours at a time on them
Old May 14, 2006 | 10:01 AM
You'll never hear that suggestion from us.
Most are not meant for small skinny 3.5-4" wheels, they overstress the shells. They are better suited for a 5-6 inch wheel. Alsmost all damages that I've seen were a direct result of the use of a VW tire.
...They are not rated for any of the speeds the typical F-body goes, load rating is questionable.
simply stated, don't use them.
Steve
Old May 14, 2006 | 11:19 AM
LS69TA's Avatar
I've used the Kumho 165 PowerStars and had no problems with them. However on my next set I'll probably just get the M/Ts. The Kumhos were only like $26 a piece, so I went that route last time, and they did fine.
Old May 14, 2006 | 12:07 PM
Thanks steve/guys I will be getting the M/T sportsmans 8 ply
Old May 14, 2006 | 12:13 PM
Strahley's Avatar
Good choice
