Rim Experts.... Widened Wheels Help!
So my wheels are 18X9 with a 38mm offset( 6.5 inches of backspace), and XXXX company is going to weld in 2.5 inches to the back of the wheel. This means thats 2.5 inches ( or 61.25mm) is going to be added to the rim. So if my calcualtions are correct the new rim is going to be 69mm offset with a back space of 8 inches... is this correct??!?!
Then with a 1inch spacer, ill have a offset of 44mm, PERFECT, right!?!?!
Thanks Guys!
Hopefully should look like this when done....
The WS6 wheel in the example you showed is a bit deceiving in that those wheels have a higher starting offset than Evo's and sit further inside the fenders, which is how that guy got away with using a spacer that big.
