is a 97blazer 2wd same as 4th gen fbody
No, the wheels on a 4th gen. will not fit a 2wd Blazer. The bolt pattern is the same but, the Blazer requires a much lower offset than the F-body. If you were to put the 4th gens wheels on a Blazer, they would most likely hit the frame.
You need 2 or 2.5" spacers to fit 4th gen wheels on a 2wd S truck depending on the offset of the wheel being used. If you had a 4x4 they'd bolt right on with no spacers.
