15x6 Up Front ?
...don't run a 165 radial tire either!! Stick with a 1573 runner or drag runner if you want to save even more weight.
...not sure why anyone would use a drag setup for a daily driver as it handles pretty bad in comparison to even a stock setup. Just driving it to car shows or events is one thing...but not an every occurance for going to/from work.
Occasionally we get folks who want to try this, what I give them as a scenerio is sort of like this...
...would you want to purchase an all season tire for your car which has bad traction characteristics and handling in comparison to a summer tire...by trying to setup a wheel setup for both daily use and drag use, this is sort of along the same lines. You'll end up having a setup that is not very good for either setup but just ok for both.
I highly disagree. I've known people that run a 15x3.5 drag wheel up fronts with 165 metric tires as daily drivers for years without any problems. Daily driver does not necessarily mean you drive it all winter, or when the roads are that bad.
Driving with skinnies on a daily driven car isn't nearly as bad as people think it is. I'm not the type that sits there and takes corners at 100 MPH either...as I do have my front sway bar removed.
A VW tire is not rated for the car, diameter is too small compared to stock which effects ABS creating even more issues. The only benefit I can see would be cost over a correctly rated tire.
When someone states daily driver, to me it means exactly that. Winter driving or bad weather is not the issue. The typical daily driver vehicle is used 10-15,000 miles a year. If you're under 5K per year, it certainly isn't considered a daily driver. it would be a leisure vehicle at this point. I believe most insurance companies consider this also.
I'd admit, I use my car on the street with skinnies BUT I only use the car to go to car shows or events with this combo. Daily driving the car just doesn't make sense when you're using a race setup on the street. Put some wide tires on it and at least have fun with it instead of driving like a Sunday driver not wanting to take turns...that's why I have a 315/275 combo as well.
I wish you luck Sebastian. Picking up a good slick/skinny combo will have great benfits for racing. But use them for racing. Using the set for daily driving you'll soon find out their shortcomings.
