Tire Rub
Old Jun 25, 2006 | 06:29 PM
SailorZ28's Avatar
Default Tire Rub
Well I bought some C5 "wagon" wheels, the silver 17"/18" combo for my 99Z28. I am experiencing some inner fender rub in the rear. Everything I have read on this site and others says I shouldn't be experiencing any problems. What is the best way to take care of this situation? This car is about to be my daily driver, and in a few months I'll be taking a long road trip down to Florida. So the last thing I want is for my tire(s) to explode when I hit a bump on the interstate.
Any help would be greatly appreciated.
Old Jun 26, 2006 | 11:15 AM
ls1_bc's Avatar
Sounds like you need to do the BFH mod
Old Jun 26, 2006 | 11:45 AM
SailorZ28's Avatar
as in Big Farkin Hammer? Will I hurt anything by knocking the fender in? Is there a particular place I should be hitting away? I don't want to break anything
Old Jun 27, 2006 | 01:35 PM
Ice Knight's Avatar
I also am wondering this question.
Old Jun 28, 2006 | 11:09 AM
69TA's Avatar
Might also want to consider getting an adj. panhard bar to center the rear better
Old Jun 28, 2006 | 02:01 PM
Hambone 7's Avatar
make sure if you do the bfh mod that the rear seat isnt folded down.
Old Jun 29, 2006 | 05:25 AM
SailorZ28's Avatar
What is a panhard bar? And why would my seat have anything to do with a hammer and my inner fender?
Old Jun 29, 2006 | 02:37 PM
sectari's Avatar
the panhard bar is the long straight bar that runs across the back of the rear end at a bit of a slant. It's supposed to keep the rear end centered under the car. The stock unit doesn't do a very good job of that.
A place that generally needs the tender minstrations of your BFH is at, looking at the driver's side inside the fender, at 9 o'clock - and that happens to be about where the rear seat lock mechanism is attached. If you keep it up and locked it'll not get moved out of alignment. I know that at least one guy reported his bad experience with that.
ls2.com has an excellent writeup of the BFH mod, with pictures:
http://www.ls2.com/forums/showthread...hreadid=223590
-sectari
Old Feb 1, 2007 | 12:36 PM
RW99's Avatar
Bump for an excellent link. Thanks!
Old Feb 1, 2007 | 02:30 PM
mcG's Avatar
mcG
how do you know if you are rubbing? i've been getting a squeaking noise when i come to a stop sometimes. i just recently put on 18x10.5 with a 295 tire.
Old Feb 1, 2007 | 02:42 PM
408Maro's Avatar
i just threw on 5/16 spacers
Old Feb 1, 2007 | 02:54 PM
RW99's Avatar
My rubbing is evident from my left rear wheel when I take a right turn at speed. I hear sort of a raspy scraping sound from the wheelwell.
Is the simple fix for this just to keep nudging the rear toward the driver's side with the adjustable panhard until the rub disappears? Or might that result in a misaligned center section?
Old Feb 2, 2007 | 12:26 AM
ablakez28's Avatar
not sure but i just had 295s put on my vette wheels and i got a case of the rubs as well. i think i need an adj panhard anyhow it hasnt looked quite right since i put the 9in in it
Old Feb 2, 2007 | 08:32 AM
Xsta Z 28's Avatar
The wagon wheel rear offset is very big and tucks the wheel into the wheel well. Either a small spacer 1/4" max on stock lug studs, and or BHF, where you can see the actual rub marks in the wheel well.
Old Feb 2, 2007 | 08:38 AM
Ericbigmac83's Avatar
I have the same wheels and had the same problem. Mine would rub when i took fast turns. I first put on a spacer, then got out the hammer. Now that i have an adj panhard bar its not an issue. And if you go the spacer route you will need longer wheel studs.
Old Feb 10, 2007 | 11:19 AM
ls1charged's Avatar
is there any local stores like autozone/ advance, that carry wheel spacers?
Old Feb 10, 2007 | 01:50 PM
99kamarokid's Avatar
u can buy them off ebay for cheap...
