backspacing 15x4 wheel
Old Jul 2, 2006 | 03:29 AM
blu98ta's Avatar
Default backspacing 15x4 wheel
What would be a good backspacing be for a 15x4 wheel. I am looking into buying a set of prostars with 15x4in fronts, and want to know what a good backspacing would be. I know for a 15X3.5 a 1.75 is good, but what about a 4" wide wheel?
Old Jul 2, 2006 | 12:45 PM
blu98ta's Avatar
will a 2.25" backspacing work on this wheel
Old Jul 2, 2006 | 03:00 PM
blu98ta's Avatar
anyone??
Old Jul 2, 2006 | 05:00 PM
z-ya's Avatar
Well on my 15x4 centerlines the backspace is 2 5/16 , so 2 1/4 is pretty close, just 1/16 different.
Old Jul 3, 2006 | 08:28 AM
Xsta Z 28's Avatar
I always read that getting 4" wheels to fit over the LS1 brakes was a nightmare?
Old Jul 3, 2006 | 08:53 AM
blu98ta's Avatar
what about 3.5" wheels??
Old Jul 3, 2006 | 09:02 AM
LS69TA's Avatar
I believe the only way you can get the Centerlines is in a 15x4, not 3.5". So they will work (Centerlines don't require grinding to fit, but don't have the ideal backspacing to keep the wheel tucked inside the fender). However, the 3.5" in a Weld wheel will require 5/16" spacers and longer studs, or grinding the calipers to make them fit.
Old Jul 8, 2006 | 12:35 PM
z-ya's Avatar
You can get convo pros both ways,the 15x4 tuck a little better but require grinding,the
15x3.5 fit as is.I have had both sizes.The 15x4 also does not have convolutions on the rim,no room for them.
Old Jul 9, 2006 | 02:36 PM
SSPerformance's Avatar
yes it was. took a ton of grind to get the 15x4 to fit with a spacer no less
