Prostars fittment question
Hi guys im new to the f body scene and had a question concerning some weld prostar rims i installed on my 95 camaro. The 15 x 10 rear rims went on with minimal caliper grinding in my case (worn brake pads?) and plenty of inner fender > inner tire clearance when the car is resting on all four wheels but when the car is lifted by a chassis lift and the rear axle goes to full extended travel the inside of my tires touch on the axle bump stops on both sides. I know that while driving the rear axle shouldnt go to full extended travel (extreme hard braking?) but what is the common practice for this? remove bump stops? trim em? dont worry about it? any advice would be appreciated.
thanks in advance jason
