Lug Nuts for 19'' Evo's
Old Jul 22, 2006 | 05:55 AM
BoneSS's Avatar
Default Lug Nuts for 19'' Evo's
I have Evo Lightnings that came with the open ended lug nuts that you used a key to tighten. Well, over time, they have kind of rounded out, and I need new lug nuts. I would like something with a closed end and something I could use a deep-weld socket on, not a key. Is this possible? It should be shouldn't it? Is there a specific size I should look for or anything? Thanks.
Old Jul 22, 2006 | 03:37 PM
TNTramair's Avatar
check thunderracing....i got my lug nuts from them for my black evos.
Old Jul 22, 2006 | 06:21 PM
00_Z's Avatar
the lugs are 12x1.50, depending on the size of your lugholes you may be able to use regualr acorn lugs.
Old Jul 22, 2006 | 08:11 PM
Nine Ball's Avatar
LS1Tech Co-Founder
regular acorns won't fit inside of EVOs. You need 12mm x 1.5 splined tuner style lugs. These are closed and have lines on the side and come with a key that lines up with the lines. You should be able to bet them from Discount Tire or ebay
Old Jul 23, 2006 | 10:06 AM
BoneSS's Avatar
Thanks Tony. That is what I ended up getting. I did use the ones that came with it, and that eventually led to them being rounded out. Very happy now!
Old Jul 23, 2006 | 10:16 AM
geo 95 bird's Avatar
go to this website http://www.mr-lugnut.com/ and u want the 5640 series this is what i got
