275/50/15 drag radial fit 15x10 welds, the reason is inside.
I have 4.22 gears and will want to run the 325/50/15, 28 inch tall tire, when I use nitrous at the track. But when I am not using nitrous which I won't be for a while I want the normal 25.6 inch tall tires and I can do this with 275/50/15, but I'm not sure if this will fit a 15x10 inch rim. What do you think?
