Do all tires fit the same?
Old Sep 2, 2006 | 11:53 PM
cha1nz1535's Avatar
Default Do all tires fit the same?
If a bf goodrich 295/35/18 tire will fit a 18x9.5 rim will a kumho 295/35/18 tire fit the same rim?
Old Sep 3, 2006 | 01:26 AM
CRAGER's Avatar
Administrator
First off 295 on a 9-1/2" wheel is too much. 275's should go on your 9-1/2" wheel. You can fit 295, or even more but you get a ballon effect.
BF Goodrich tires I have noticed are a little bigger then some other tires. On my 17 x 11 wheels when I had 315 Nitto Drag's I had no problems with fitting under the car. When I bought BF Goodrich G-Force KD's I had rubbing issues bad. The KD's were about an 1" wider then the Nitto's. I had to roll my fenders and beat in the wheel well area.
As far as the Kumho's fitting the wheel, sure they'll fit the wheel, a little over sized but they will go. When it comes to how big on the overall width I can't say.
Read the sticky's up top, and try a search next time.
Peace,
Craig.
Old Sep 3, 2006 | 12:23 PM
cha1nz1535's Avatar
What do you mean balooning effect?
Old Sep 3, 2006 | 05:45 PM
CRAGER's Avatar
Administrator
The tire is squeezed onto the rim making the tread a ballon, not flat and you will have less of a contact patch..
Peace,
Craig.
Old Sep 3, 2006 | 06:31 PM
cha1nz1535's Avatar
ohh makes sense...do you think the balooning effect will happen with the 285s
Old Sep 3, 2006 | 06:46 PM
phantomzer0's Avatar
I run 285's with no problems whatsoever on my 9.5's. They are BFG KDWS, so they should be pretty similar.
Old Sep 3, 2006 | 07:26 PM
rjkZ28's Avatar
i work in the tire industry, and yes 285 are the biggest recommended size for a 9 1/2 wide rim. like crager said above you can put bigger but you end up with the balloning effect. hope that helps.
Old Sep 3, 2006 | 07:52 PM
shaun's Avatar
i was wondering this two.i went looking for a set of tires for a car at a used tire store across from my house and they had a few 275/40/17's that i looked at[looking for a tire for a clunker]and just for comparison
1 was a f1 goodyear and 1 was a bfg kdw and they both looked a lot wider than the new set of falken 451's i put on the car and they are 275's also and they look really narow.
