Fitting 79mm 19x10 C6 rims to my Formula, the experience.
As promised, pics. I will say that these adapters are very high quality, I had absolutely NO fitment issues, and install/ease of use is amazing. The ride quality is not changed, there's no vibrations, noises, anything. The money is well sapent, IMO, and the peace of mind associated with it is priceless. Plus, they got here in two days ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Anyways, I apologize for the lack of quality. It's overcast outside, the car hasn't been done up in a week or so (so no tire shine, etc.). But it gives a general idea. Also forgive my off-road appearance, but the car was lowered and it not only make my traction worse, my duals hit EVERYTHING![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://www.darkformula.net/pics/c6/newc6s1.jpg)
![](http://www.darkformula.net/pics/c6/newc6s2.jpg)
![](http://www.darkformula.net/pics/c6/newc6s3.jpg)
![](http://www.darkformula.net/pics/c6/newc6s4.jpg)
Just refresher info:
2006 Corvette Z51 polished wheels
Front are 18x8.5 w/ 245/40/ZR18s
Rear are 19x10 w/ 295/35/ZR19s
I'm probably start another thread just for the pics so people don't have to dig through the tech info to find the pics.
They work perfect. I've hit bumps/potholes (******* taxes going where again?), taken on-ramps at 70mph, and cruised home doing 140+ this morning from work, and everything is as stable and vibration-free as stockers.
Definitely a worthwhile investment!
i have skulte adapters on my car. i widened my ws6 wheels to 11'' out back and the adapters have been flawless. i've only got about 400rwhp, but i've torn into it plenty of times and they've never even so much as loosened any on me. you'll be happy with your purchase
Originally Posted by DarkFormula
Obviously everyone didn't know, and a search for "C6 rims" and "C6 wheel fitment" came up with nothing about the OEM 19s.
https://ls1tech.com/forums/showthrea...highlight=79mm
What part of my previous posts don't you comprehend? None of my search terms included "79mm", as a matter of fact had I know what the offset was (which the search didn't pull up posts with that info either), then maybe I'd have found my answer.
Yeah, I say so.
Yeah, I say so.
#32
FYI: ls1tech searching does not include words less than 3 characters long.
Try searching for C6 and you will see.
Thanks for posting this because I just bought a set like yours for my '00 Z28 Vert and I knew it needed spacers and I knew about skulte.com because I own lots of 3rd gens but I did not know what size spacers were needed.
Good job on the write up.
#33
Yeah, I say so.
Yeah, I say so.
I went to ebay did a search, emailed the company for their suggestion-and got the 1.25 inch adapters for the rear delivered in short order. been rolling ever since. But rule one no matter how cheap the price on the wheels is to find the specs. If you don't you could spend a significant amount of the money you thought you'd saved just trying to get them to fit.
#34
I made the mistake of assuming that if the 18s fit all the way around, the 19s would as well. I may have plety of experience with our vehicles, but mostly in the mechanical/electrical side of things and marginally in the "looks" department.
Yes, if many people had seen my post first, it would have saved me some headaches and beating on my car. **** happens, we just learn from it. However, if someone in my place searches now, they'll come up with this thread and learn a lot. The benefits of people's experiences like mine and some others in here.
Thanks for the help from everyone. Better late than never, and I've learned a lot as well.
#39
Taken from the Skulte Performance website:
Various Rim Dimensions
Rim Name Size Offset Backspacing Suggested Thickness (3rd Gen)
Corvette 84-87 16x9.5 38mm 6.6" 2"
Corvette 88-96 17x9.5 56mm 7.3" 2.25"
Corvette GS ZR1 style 17x9.5 50mm 7" 2"
Corvette ZR1 style (Low Offset) 17x9.5 38mm 6.7" 2"
Corvette ZR1 style (Low Offset) 17x11 36.5mm 7.397" 1.25" Rear
Corvette ZR1 style (High Offset) 17x9.5 56mm 7.4" 2.25"
Corvette ZR1 style (High Offset) 17x11 50mm 7.93" 2" Rear
C5 Corvette 97-2000 17x8.5 front 56mm 6.8" 2"
C5 Corvette 97-2000 18x9.5 rear 63mm 7.6" 2"
C5 Corvette Z06 17x9.5 front 54mm 7.2" 2.25"
C5 Corvette Z06 18x10.5 rear 58mm 7.9" 2" Rear
C6 Corvette 18x8.5 front (GM 9594351) 58mm 6.53" 2" Front & Rear
C6 Corvette 19x10 rear (GM 9594353) 79mm 8.11" 2.25" Rear
C6 Corvette Z06 18x10 front
C6 Corvette 19x12 rear
Camaro 82-92 16x8 front 0mm 4.35"
Camaro 89-92 16x8 rear 16mm 5"
Camaro F1 ZR1-style 17x9 50mm 6.8" 2"
Camaro 93-97 16x8 55mm 6.5" 2"
ROH ZS 17x9.5 5 mm 5.472"
ROH ZS 17x8.5 -7 mm 4.5"
