315's on a 10 inch rim? NO NO?
Old 12-20-2006, 10:51 AM
blown00ls1's Avatar
Default 315's on a 10 inch rim? NO NO?
I bought 18x10 inch tt2's and i want to run bfg kdw's, i would like to use the 315/30/zr18 that they have, but it says 10.5 to 11.5, would putting that tire on a 10 inch rim be a no no?
Old 12-20-2006, 11:30 AM
LS69TA's Avatar
It should be fine. a 1/4" on either side isn't really going to hurt anything.
Old 12-20-2006, 12:46 PM
michaelg589's Avatar
I dont think that would be safe. 10.5" is about the narrowest you should go. and a 1/4 inch on either side DOES make a difference.
Old 12-20-2006, 01:01 PM
RoastEmSS's Avatar
running big 315 BFG g force TA DRs on my 10.5" so you should be fine
Old 12-20-2006, 02:27 PM
LS69TA's Avatar
Guess I like living on the edge
Old 12-20-2006, 04:43 PM
Xsta Z 28's Avatar
No way in hell would a push the limits on a 18" diameter sidewall . . .
But it's your car and your life. . . . Manufactures have recommendations for a reason, and reasons not to be ignored.
Old 12-20-2006, 04:53 PM
'96 Z28SS's Avatar
bump down to a 295, you wont see much difference in perf. and you will stay safe.
Old 12-20-2006, 05:20 PM
Fulton 1's Avatar
BFG recommended minimum wheel width for 315/30/18 KDW is 10.5"...
ref: http://www.bfgoodrichtires.com/specs...-a-kdw/22.html
Old 12-20-2006, 05:38 PM
Donohue96M6Z28's Avatar
what wheels do you have that are 10.5in wide? the zr1s? sure they arent 11s?
bjm8's Avatar
+1 for bumping down to 295's. The performance difference is negilgible and it sure beats having a tire unseat at 90mph...
Old 12-20-2006, 05:59 PM
RoastEmSS's Avatar
18x10.5 Z06s with 315 BFG DRs
Old 12-20-2006, 10:58 PM
camarokid02's Avatar
wahts the offset, and did you use a spacer?
Old 12-20-2006, 11:08 PM
skatinjay27's Avatar
i was gonna say the same a exta said.it may work with a 17 but a 18 has way to small of a side wall
Old 12-20-2006, 11:56 PM
RoastEmSS's Avatar
No spacers, and they are original GM wheels off a z06 so the offset is 56? i believe
Old 12-20-2006, 11:57 PM
gotchya. I was confused for a sec. the z06s look good.
Old 12-21-2006, 12:13 AM
Old 12-21-2006, 08:58 PM
SSNISTR's Avatar
So I guess you had them chromed?
Quick Reply: 315's on a 10 inch rim? NO NO?
