weld draglites
Old Jan 18, 2007 | 04:12 PM
BES Stroked Nova's Avatar
Default weld draglites
i just tried to put on my new draglites. 15 x 8 with 5.5" offset. they dont clear the brakes in the back. any idea's?
Old Jan 18, 2007 | 08:36 PM
2_wacko's Avatar
https://ls1tech.com/forums/showthrea...nding+calipers
Old Jan 18, 2007 | 10:11 PM
Fbody98's Avatar
use .5 in spacers if you trust them
Old Jan 19, 2007 | 12:40 AM
The LT1 That Could's Avatar
GRIND LIKE MUH FUGGA! They'll fit!
Old Jan 19, 2007 | 09:14 AM
LS69TA's Avatar
Be prepared to spend alot of time with the grinder. Grind/test fit/grind/test fit/etc.
Old Jan 21, 2007 | 07:09 PM
so could i use a spacer for tack use? I have a strange 12 bolt already, with the studs that came on the rear end, should i buy longer ones with wheel spacers?
Old Jan 21, 2007 | 07:36 PM
LS69TA's Avatar
On the rears I'm not sure how much of a spacer you would have to run to get away without grinding. It'd be a fairly large one though.
Old Jan 21, 2007 | 09:50 PM
i dont want to grind all that much, these are for the track, and some street if someone wants to go from a stop. i just think a spacer would save me some grinding, i hope.
^^^ Nice T/A you had there in your sig pic, but where did you get that lift kit from? sorry you made fun of a SS, just had to get ya back.
Charlie
Old Jan 22, 2007 | 05:06 AM
LS69TA's Avatar
That was the custom "Stock WS6 springs lift kit" Here's one after the G2 springs:
Old Jan 22, 2007 | 10:11 AM
dont worry, my SS has BMR 1" lower in front and stock ride hight in rear, so i call mine the rancharo lift kit....
