my lsat prostar question
Old Jan 23, 2007 | 11:00 AM
97lt1z28's Avatar
Default my lsat prostar question
I am getting prostars and wanted to make sure that i had everything on mny list i need
1. 15X10 rims with 7.5 backspacing
2. 325-50-15 mickey thompson drag radials
3. 15X4 rims up front with a 5/16 back spacing?? is that right?
4. i need to know the tire size that fits a 15X4 front tire and a brand you like.
and as far as the front tires i was thinking mickey thompson front runners- 22.5X4.5-15 (would that work ok?)
oh yeah i also need lug nuts, what size and brand would you recommend
Can you guys think of anything else i need? thanks
Old Jan 23, 2007 | 11:12 AM
LS69TA's Avatar
15x3.5 with 1.75" bs (only bs offered ont he 3.5s). You might be able to go with the 4" wheels with LT1 brakes, but the 3.5s would be easier to sell/trade down the road. 22" is too short on the front. I'd run a 26x7.50 Mickey T. Sportsman on the front. You'll need shank style lugnuts 12mmx1.5 I think. Don't get the Weld lugnuts, they will rust in no time.
Old Jan 23, 2007 | 03:01 PM
00SS4780's Avatar
x2 on the 26" tall tire. 22' is way too small. The rest looks ok but I would get the 3.5 if it was up to me.
Old Jan 23, 2007 | 03:27 PM
chevynut50's Avatar
Unless you're going to grind the front calipers you'll need 5/16 inch spacers for the front. I just installed draglites on my car and unless the prostars are different through the wheel hub you'll need longer studs especially for the front (3.25" long is what I used front and rear).
Old Jan 23, 2007 | 07:00 PM
01 BERGER CAMARO SS's Avatar
3.5 in front and a spacer, no need for longer studs. Thats how im running my hawk.
Old Jan 23, 2007 | 07:51 PM
chevynut50's Avatar
I'm not sure how long the stock studs are on a late model, but on my 97 no way would I not use longer studs with the 5/16 spacer.
Old Jan 23, 2007 | 10:09 PM
LS69TA's Avatar
Yea, on my WS6 with the spacer on the front I only got 4, maybe 5 turns of the lugnuts. After grinding, it was like 12 or 14.
Old Jan 24, 2007 | 10:15 AM
97lt1z28's Avatar
if i run a 4 inch tire do i still need the 5-16 spacer because honestly i was just looking at the new wheels that summit is putting out the look exactly like the prostars and are a lot cheaper. what do you guys think about those?
Old Jan 24, 2007 | 10:22 AM
streetassasin's Avatar
I dont think you can get them with the right b/s for your 4th gen
Old Jan 24, 2007 | 11:29 AM
LS69TA's Avatar
Somebody posted that the Summit brand wheels fit without grinding. I guess if you wanted to try them it might be worth it. Just don't mount the tires until you are sure they fit right.
