bfh?
Old Jan 23, 2007 | 11:38 AM
onebad400's Avatar
Default bfh?
what size tire could i run on a 18x10.5 rim without doing this mod.
big f'in hammer? what would i need to hammer?
Old Jan 23, 2007 | 11:51 AM
mcG's Avatar
mcG
i heard you want to "massage" the fender well at around 9 o'clock if you are looking at it dead on. i just got 18x10.5 wheels put on the back with a 295/35/18 and it clears everything, with no modification
Old Jan 23, 2007 | 03:29 PM
Xsta Z 28's Avatar
All depends on the offset . . . I have a 295/35ZR18 on my 10.5" wheels and no inner wheel well massaging . . .
Old Jan 24, 2007 | 07:31 AM
onebad400's Avatar
they are a 54mm offset will that work
Old Jan 24, 2007 | 08:31 AM
Xsta Z 28's Avatar
With a 295 series tire, most likely you will be fine. If anything just a tiny bit where the tire rubs, if at all. My old 58 mm offset, which tucks the wheels inwards 4 mm compared to what you were buying needed only a small amount of BFH.
Old Jan 24, 2007 | 09:01 AM
LS69TA's Avatar
I had 295s on a 10.5 and didn't have to touch a thing either.
Old Jan 24, 2007 | 02:54 PM
onebad400's Avatar
even if i lower it a inch
