pics of 295s
Old Feb 1, 2007 | 10:45 AM
michaelg589's Avatar
Originally Posted by JR HAWK 9
I agree........
I have 295/30/18's on my rear 10.5" wide rims.
nice firehawk! are those michelin PS2s?
Old Feb 1, 2007 | 12:21 PM
Rickys S/C Z28's Avatar
Originally Posted by BAN-LS1
It really depends on what tire you buy. A firestone and some others run narrow and on a 10.5 they look too small. The GSD3's however would NOT fit on a 9.5!! https://ls1tech.com/forums/showthrea...uff+wheels+295
well guys they seem to work here??? and no my mind is not made up iv got 6 more months here in iraq befor i make up my mind, so if yall have any pics with 285s then lets see them
Old Feb 1, 2007 | 02:59 PM
those are bulging too much. they will wear faster and wont be the safest at highspeeds or high speed cornering
Old Feb 1, 2007 | 03:01 PM
JR HAWK 9's Avatar
thanks!
yep, they are the PS2's
Old Feb 2, 2007 | 11:00 AM
any pics of 285s????
Old Feb 3, 2007 | 09:36 AM
pwrtrip75's Avatar
Your kidding right? Do you prefer the rim sticking out wider than the tire like a ricer? Those look perfect. And if you put the correct air pressure in you'd be surprised how they dnt wear. Different size tires, weight of the car, makes a difference in what air pressure. Dont go by the max rating on the tire....that is the max.
Old Feb 3, 2007 | 12:27 PM
umm no, i prefer my tires to fit right on the rims. I dont like to half *** it and buy all the same size wheels but try and put different size tires on them.
Old Feb 4, 2007 | 01:13 AM
well guy any one got pics of 285s
Old Feb 5, 2007 | 01:27 AM
ttt....
Old Feb 5, 2007 | 02:09 AM
GIGAPUNK's Avatar
Most manufacturers actually publish a list of min and max wheel widths per tire size.
Dave Coleman of SCC magazine said that for cornering, 0.5" narrower wheel than the max listed is best. Fred Puhn, author of "How to make your car handle" (originally published in 1981), says, the widest rim that the MANUFACTURER suggests. Personally i think that Dave is right on with modern tires.
Here's a link to Falkens 615 suggestions. I'm planning on the 275/40/17 for my 17x10.5 Halibrands.
http://www.falkentire.com/rt615_sizes.html
Old Feb 5, 2007 | 08:35 AM
Turo's Avatar
Question, are you considering 295 for the wide tire look? Because if so, there is very little difference between a 285 and 295 both on a 9.5" wheel. That weel width isn't wide enough to get the full effect of the 295, unless you are using a tire which tends to run narrower than most, in which case it would defeat the purpose .
Old Feb 5, 2007 | 11:39 PM
  #32
yes and no i want the wide tire look but im going to be makeing about 500 RWHP so i need some thing that looks good and will stick to the road, my thought was the bigger the tire the better it will hook up????
Old Feb 5, 2007 | 11:53 PM
  #33
LS1ATEU's Avatar
Originally Posted by SS DNA
Ahhhh let me snap a quick pic......
do those tires hook?
Old Feb 6, 2007 | 08:50 AM
  #34
Turo's Avatar
If there is one thing I have learned with the tires I am currently running is that sometimes the tire material/treadwear rating is MUCH more important for traction than the extra 10 or 20 mm in width. If I was you, I would just get a sticky 275 tire on those rims. Just my opinion .
Old Feb 6, 2007 | 12:05 PM
  #35
yes iv been learning the same thing, but i seen a 285 on a 18x9 1/2 rim and it looks great and he says it hooks very well i think he said it was the bfgs so i might go that rought thanks for your opinion. what kinda tires you think?
Old Feb 6, 2007 | 12:49 PM
  #36
Turo's Avatar
Depends, what are you going to use them for? Street/strip? drag race only? Autocross?
Also, what's more important, traction or treadwear? And don't say both, it's a tradeoff .
Old Feb 6, 2007 | 01:16 PM
  #37
im going to say traction, with as much treadwear as i cant get. the car is a DD and will see track use at least one a mounth, or do you think i should go with getting a set of tires that wear well and just but a set of DRs for the strip????? man im so comfused right now i dont know witch way is up
Old Feb 6, 2007 | 01:43 PM
  #38
GIGAPUNK's Avatar
BFG KDs are about as good of a street tire as is made. Just don't expect them to last much more than a year. The falkens I linked above are almost as good and significantly cheaper, but they are pretty noisy and tread wear is in the 200s as well. The Kumho MX is right there as well and even cheaper yet. Unless you're in a $ racing series stick with your street tires. Next time you get revved on out in the street you'll be glad that you know exactly how to launch. Plus street tires are WAY easier on drivetrain. And I concur with everyone above: compound trumps tire size almost everytime.
Old Feb 7, 2007 | 09:35 AM
  #39
sweet thanks bro guys keep it comming
Old Feb 7, 2007 | 10:38 AM
  #40
tim99ws6's Avatar
I ran the Supercar 295s on my 18x9.5's for years and never had an issue. There was no uneven treadwear and no effect in handling, at least no diminished effect.
As many have said, generic tire numbers(275/40/18...295/35/18..etc) are NOT what you should go by. Do a little extra reseach and find the true tread width and contact patch for each brand/style tire. As someone said before, a 275GSD3 is a wholly different animal than a 275Nitto.
Yes there is a "little" wiggle room with what you can put on a 9.5" rim, but don't go sticking a 315 on there!!!
