Want your thoughts/ideas
Old Feb 27, 2007 | 02:06 AM
Randy_S's Avatar
No wait, I change my mind. I vote SPOKES! Lots and lots of spokes with a lip.
Just kidding of course.
Old Feb 27, 2007 | 02:36 AM
LMz28's Avatar
Originally Posted by bearcatpride
Perhaps a design similar to the C5 Z06 wheel with a deep lip
yeeeeess! thatd be so sick. get a huge lip on there, and make it less flowy. id like to see deep angles and straight lines. ooOOOOoooo...have you guys thought about a machined wheel? next wheels i get are coming from you guys.
Old Feb 27, 2007 | 08:36 AM
69TA's Avatar
Couldn't you guys CNC the barrel overage while mounted to a spare center?
Then you could do it per order basis. After owning three sets of Fikse wheels, FM5, Profil 10 x 2. I got tired of trying to keep the part in between the spokes cleaned.
Also in my opinion that part made the wheel look kind of sloppy. That's why for some reason not too many people will show the profils 10's face on. But always on an angle to avoid showing the barrels peeping thru.
But I feel the end result would be worth the effort, as it would free up the opening on the end webbing making the wheel look bigger. And also shedding some additional weight.
I even considered doing a set on my own with an air grinder. But it would take me for ever and worried about upsetting the balance of the wheel. Being that it was done my hand.
Originally Posted by Fikse USA
Removing the step in the inner and outer rims would take redisigning our entire lineup, inside and out, so unfortunately that's not an option. The Profil 10s are already available with anodized centers.
Kenisis is a nice looking wheel. Enjoy it!
-Danny G.
Old Feb 27, 2007 | 11:52 AM
Fikse USA's Avatar
Nothing of that sort can really be done on a per order basis, because of the cost of tooling. Not only would the tooling have to be changed for rim halves, but our centers would have to be made in a larger diameter. However, who's to say what the future may have in store....
I would highly recommend against ever trying to remove the step in our wheels with an air grinder, as the rim halves are rolled that way, and the grinder would penetrate through the metal before you got the inside diameter you're trying to acheive. Thus creating a large hole in your rim. Having said that, it would not reduce weight either, as it is not a solid piece, and your center would no longer have a place to bolt up to.
I hope that all makes sense.
Thanks,
Danny G.
Old Feb 28, 2007 | 05:21 AM
Randy_S's Avatar
I guess no one likes my idea of wire spokes with a dish huh?
Honestly I would like to see a set out that only cost me either an arm OR a leg. Not both. Yall make some beautiful wheels though!
Old Feb 28, 2007 | 09:18 AM
ddnspider's Avatar
Danny just looked at your wheels on the website and noticed something.All the wheels have exposted lug holes.Have you ever considered making a wheel that had a cover to hide them that was either machined or whatever that said FIKSE across it in italics?some of those wheels would look killer like the Profil 5S if the spokes were a bit longer and the center section was a tad smaller with a polished/machined cover that had FIKSE in italics.
Old Feb 28, 2007 | 10:55 AM
Fikse USA's Avatar
I completely see where you're coming from, on the appearance end. However, our wheels are built primarily for racing. Therefore, doing something of that sort would sacrifice the structural integrity and rigidity of the wheel.
Places like CCW make some gorgeous wheels that are similar to what you're describing. However, not to discredit thier product by any means, they aren't built for racing. They are a great street wheel, with a great look.
By the way, I'm not trying to discredit your idea either. I just want to clarify how our wheels are built, and what they're built for. Hope this all makes sense. Keep the ideas coming guys! :thumbs:
Danny G.
Old Feb 28, 2007 | 11:27 AM
milk's Avatar
I agree with some of the others guys, somthing similar to the 10 spoke but with a nice 4'' lip in the back would be nice.
Old Feb 28, 2007 | 11:44 AM
Got Me SOM's Avatar
besides the design, maybe see if you can engineer a wheel that can go up to 12" wide on a stock width rear end.
then we can run some 345's
Old Feb 28, 2007 | 11:50 AM
Fikse USA's Avatar
Once again, just to make the way backspacing and offset works, clear. A 4" lip is only attainable on certain applications. On a 4th gen camaro, for example, the most "lip" you can achieve, without narrowing your rearend or flaring your fenders, would be a 2.5". Otherwise your car will end up looking like a roller skate, with the wheels protruding out 1.5"...
Old Feb 28, 2007 | 11:51 AM
Fikse USA's Avatar
Please see above post
Old Feb 28, 2007 | 12:34 PM
  #32
SLPHawk300's Avatar
Old Feb 28, 2007 | 01:12 PM
  #33
SSilverSSurfer's Avatar
Originally Posted by SLPHawk300
@avatar
Old Feb 28, 2007 | 05:16 PM
  #34
ddnspider's Avatar
Danny G.
how would that change the structural integrity?as far as having hidden lugnuts.the wheels could basically look the same but have a removable cover for the center section.that way you'd still have the race crowd and the bling crowd
Old Feb 28, 2007 | 05:29 PM
  #35
SPANKY LS1's Avatar
The only thing "wrong" with your wheels is that stepped lip in my opinion. When someone buys a 17", 18", or 19" wheel, they want it to look like a 17", 18", or 19" wheel. The stepped lip cheapens the look of the wheels IMO. Other than that, the styles you guys already have out are timeless, FM5s have been out as long as I can remember, and they are still one of the best looking wheels for LS1 cars. "Modernize" the wheel designs you already have, how much more would tooling cost for a totally new wheel versus "fixing" the lip?
FYI, CCW doesn't make any wheels without exposed lug nuts. They are also raced successfully, but this is your party.
Shawn
Old Feb 28, 2007 | 05:31 PM
  #36
FH212's Avatar
How about making the FM/5 or others available with a flat dish lip instead of the stepped one?
Old Feb 28, 2007 | 06:12 PM
  #37
Fikse USA's Avatar
Before anybody goes jumping to conclusions, I was referring to elongating the spokes, and making the center section a tad smaller... Covering lug nuts wasn't even something I read, as we would never consider making our wheels look anything like a Prime...
FYI see above post... I was referring to spoke design.
As I said before.. We primarily make RACE wheels, and the main objective behind a RACE wheel is to make them strong. Now, do you have any idea what a stepped rim is there for?
Old Mar 1, 2007 | 08:51 AM
  #38
Xsta Z 28's Avatar
Covered lug nuts =
Old Mar 1, 2007 | 09:05 AM
  #39
FH212's Avatar
Originally Posted by Xsta Z 28
Covered lug nuts =
I would have to agree.
Old Mar 1, 2007 | 12:35 PM
  #40
ddnspider's Avatar
thats a nice broad statement that all hidden lugnut wheels are ugly.what about for SUV's with large wheels?i dunno what the point of this thread is anyways if every suggestion was told no and it was stupid
