M/T 315 17" installed pics
#44
Originally Posted by NA$TY-TA
THats fine..... ill just laugh at you when the tire blows off the bead and you post up about wrecking your car......
I wasnt laughing at the safety issue, I was laughing about your "see what happens if you post it" comment. Its forbidden if someone post a picture of some thing you say isnt good.
Back on topic, did M/T say they was going to make the side wall softer? That would be sweet. Also wont the higher tread wear affect traction? I sure hope they do last longer than the 7k I got out of the others.
#45
Originally Posted by my94blackz
I ran probably made 50 passes between the BFG's and Nittos together and didnt blow the tire off the bead.
Its not what I say... its what the owners of ths baord have posted up as a guidline and ""Sticky's"" for people to read and be safe.....
Its also following what the makers of the product have written for saftey precations......
Im not saying it CANT be done..... im just saying its not safe and i HAVE seen what can happen when ya dont follow guidlines......
Kyle
#46
nitto's 315's with work on a 9.5 wheel because they are about a inch skinnier then M/Tand other tires! Nitto's run skinny! Here are some pics of 315's on 17x9.5 wheel with no problems
I wouldn't buy 315's and put it on a 9.5 wheel but this guy did and had no problems at all! With the nitto's being skinny you can get away with it!
#48
Originally Posted by iamsickofitall
doesn't anybody read the stickies? 315's will not fit on a 9.5" wheel
#50
Originally Posted by motorbuilt
BS, ive ran 315/40/17 nittos on 9" stock WS6 wheels with no problems, 3 sets actually
No one said it CANT be done... it was just stated it isnt safe and people have crashed because of it.... You may not have with your last set/ sets of tires..... but someone has.....
Originally Posted by MIGHTYMOUSE
i ran these tires little hard tonight, got the turbo back on the car, about 12# boost they seem to do very nicely.
Bad *** David....... so that means the car will be able to make it down here on the 5th of May?????
Kyle
#53
No....a nitto 315 measures fine to fit *SAFELY* on a 9.5" wheel.
Now granted this is because the nitto measures about an 1" narrower than m/t's etc of the same size
#54
That just looks a ton better. I can't wait to get a REAL 315 tire on here.
#57
you'll think twice about mounting them to a 9.5" rim.
there's a pretty big difference in the width... FWIW
#58
what is roll out on those new M/T and do u know how tall they are because there site said it could change when they finally come out. I have used M/T in 275x17 but are way to short and look stupid on a C5 vette. Looking for about 26 true inch tire.
