what happens when...
Old Apr 4, 2007 | 03:01 AM
toofless916's Avatar
Default what happens when...
a brake caliper comes off while on a freeway and gets stuck in between the rotor and wheel shredding the inside of the wheel and knocking off the the balance weights???
do i need to have it re-balanced or replace the wheel?
Old Apr 4, 2007 | 03:47 AM
EDS01SS's Avatar
from the sound of it you should probably replace the wheel. yes it could probably be rebalanced and maybe be fine but the wheel could also come apart on you later on and cause you and your car alot more harm.I personally wouldnt trust the wheel right now and would replace it.
Old Apr 4, 2007 | 05:37 AM
DopeFedZ's Avatar
I would replace the wheel. What caused your caliper to fall off?
Old Apr 4, 2007 | 10:29 AM
SSilverSSurfer's Avatar
pics?
Old Apr 4, 2007 | 12:16 PM
one of the bolts that hold my caliper bracket thing on snapped and the threads in the others are completely stripped...i dunno it just happened outta nowhere and i put like 3000 miles on it since i changed my brake pads...
Originally Posted by SSilverSSurfer
pics?
imma get em up soon...
Old Apr 4, 2007 | 12:32 PM
DopeFedZ's Avatar
Man that sucks. Well at least it wasn't more serious than just your wheel messing up.
Old Apr 4, 2007 | 12:48 PM
here are the pictures of what it did to my wheels...i dunno if its too bad but yall take a look...
and here is what it did to my rotor
Old Apr 4, 2007 | 12:53 PM
i cant see those pics i posted???? can anyone see them?
Old Apr 4, 2007 | 01:00 PM
Cole Train's Avatar
yeah they work fine. I wouldn't worry about the rim. It'll be fine. i had that happen on my '00 V6 camaro. One of the bolt worked it's way loose(don't know how) and came off. I limped it home and found a replacement bolt. just left a scrap like the one you posted in the rim. Ran it for 2 years like that and no problems.~Cole~
LT1's Avatar
LT1
Might be able to get away with it, could stick that rim in the rear if its the same size out back, but i would get a new rim if it feels like your getting a vibration from the wheel not balanced properly or if your having to stick too much wheel weight on there.
Old Apr 4, 2007 | 01:05 PM
yeah i think imma just have it re-balanced at a shop to be on the safe side cuz what it did was ripped off all the little weights that balanced the wheel out..
Old Apr 4, 2007 | 01:12 PM
cocimitch's Avatar
I think if you get it rebalanced, the rim will be OK...now the rotor on the other hand.....
maybe try to get it (actually both sides) turned and they should be OK too.
Good Luck
Old Apr 4, 2007 | 01:52 PM
rim is fine like they say, i was expecting alot worse your lucky sir
Old Apr 4, 2007 | 02:06 PM
TheLS1Kid's Avatar
The rim looks fine IMO.
Just get some new rotors, bolts, and pads if you lost them.
Old Apr 4, 2007 | 02:22 PM
my bolts snapped and stripped the threading on the part that holds the caliper in place...so i dunno what imma do about that yet
Old Apr 4, 2007 | 03:10 PM
TheLS1Kid's Avatar
Damn that sucks man.
Maybe you can fine someone who is parting out their mounting bracket.
Old Apr 4, 2007 | 03:29 PM
actually i was wrong...i got the stripped bolts out and the threading is still intact...the PAB isnt supposed to have threads so i dunno what i was thinking earlier...but i was told that i shouldnt have to turn my rotor
Old Apr 4, 2007 | 09:23 PM
FireSilverLullaby's Avatar
How did that happen, were you breakin real hard. just wodnering if warped rotors could cause that.
Old Apr 6, 2007 | 09:04 PM
naw didnt use a torque wrench and didnt tighten the bolts enough...did it to myself
