Qustion about prostars
Old Apr 8, 2007 | 04:25 PM
Italiankid77's Avatar
Default Qustion about prostars
I was wondering what i have to do to fit prostars on my 02 WS6,and what is the best size for the rear??I have the fronts i just need to know what I need for the rear thanks guys.
Old Apr 8, 2007 | 04:27 PM
TRU-2GM's Avatar
15x10 with 7.5 backspacing for the rears, and get the grinder ready! You have to grind the brake calipers down quite a bit to get them to fit.
Old Apr 8, 2007 | 04:33 PM
Dam i was afraid of that,thanks man.
Old Apr 8, 2007 | 04:34 PM
And some one was telling me i need to put spacers on the fronts,is that true??
Old Apr 8, 2007 | 09:41 PM
TRU-2GM's Avatar
Ya i run spacers on the front of mine, i cant remeber the thinkness of them but im sure someone will chime in and tell ya which size you need.
Old Apr 9, 2007 | 06:05 AM
LS69TA's Avatar
5/16 spacers and longer studs for the front if you don't want to grind the calipers. I had 15x10s with 6.5" bs on my WS6 and liked how they looked. Flush with the fender, and a tad more deep-dish looking.
Old Apr 9, 2007 | 10:33 AM
1hotls1's Avatar
Don't run the spacers on the front. Just go ahead and grind all four calipers and be done with it. Its really not nearly as bad as people make it out. I spent about 20 minutes on each caliper.
Old Apr 9, 2007 | 11:49 AM
LS69TA's Avatar
I certainly would run longer studs if you go the spacer route on the front. I could only get like 4-5 turns of the lugnuts with my 5/16 spacers and stock studs. Not safe at all IMO compared to 13-14 turns after grinding.
