What to do to make Z06 wheels fit F-Body?
Here is a pic of the 53mm offset ZO6 wheels. The rears are 18x10.5 and I have 295/35/18 BFG KDW 2's and had to do no BFH'ing at all. I did not have to remove the bumpstops, have no problem taking the tires on/off with the rear end in the air. They bolted up withe no problems or modifications at all. I may install a 1/4 spacer to push the rears out just a little.
I have 18x9.5 with +56mm offset up front and 18x10.5 with +58mm offset. I put a 5/16" on the rear and I'm lowered with a pro-kit. No BFH, no fender rolling, and no rubbing issues at all.
#32
is that a spacer you mean???
#35
I would think so. or even a regular autoparts store. I got mine at this place called Beacon, they do alot of stuff with rims and just overall modifications. However on a camaro, it might be different. I think the fenders stick out a little more on a firebird. 5/16" might be too big for a Camaro.Get 1/4" and 5/16", which ever works better, return the other. theyre cheap.
#36
![](http://rebob5.250free.com/DSC01609.JPG)
