View Poll Results: which wheels for a DD Camaro?
17x9.5 all the way around
23
17.97%
17x9.5 in front and 17x11 out back
105
82.03%
Voters: 128. You may not vote on this poll
Which ZR1's for a DD Camaro?
Originally Posted by LS1speedy
Are 11s outback good to go on ws6 and SS fbodies?
You just have to have a +36mm to +50mm offset.
If you go with the +36mm offset on a camaro, the tires will stick out about 1/4 inch. Trams Ams have a slightly larger wheel well so the +36mm offset will work on them.
The +50mm offset will work on both Camaro's and Trans Am's.
Either way you will most likely have to BFH.
Originally Posted by LT1
little bit of BFH, and rolling up your inner fender lip in the rear.
The amount of BFH (beating the inner fender to make room for the tires) that needs to be done depends largely on what tires you will be running. Good Year GS-D3, BFG KD, Yokohama AVS Sport are some of the widest tires for their numerical size and will require the most bfh. Nittos are the skinniest.
Originally Posted by MannyZ28
Yeah...and you should have an adjustable panhard bar so you can center the rear end properly, and maybe some LCA's, most aftermarket ones are skinnier than those stamped steel stockers, bit more clearance there. Also, since you are putting those big meats on, wheel hop might be more of an issues, the LCA's will help control that.
for a DD just go with the 9.5's, 11's are crazy, they also will require some work to fit, and probably a panhard bar, so if its just DD go with 9.5, but if you want a sick DD get 11
Definitely get the 11s out back. They look sick. I have 17x9s in the front and 17x11s in the back and daily driving feels no different than when I had 9" all the way around.
