What PSI in 295/35/18's?
I run about 45 psi front and 35-40 psi rear in 285-35-18's. That's about the best I could do and keep tire wear consistant on the street. For ultimate cornering you might want a little more pressure in the front but that will vary depending on the tire and the sidewall stiffness.
Originally Posted by TroubledWine3
I keep 40 in the front(275/35/18) and 35 in the rear(295/35/18) for everyday driving.
Typically you run higher psi in the front to prevent sidewall rollover during hard cornering and less psi in the rear to get better traction. I found that with my Nitto 55's the psi's I listed worked best for performance/tire wear. Each tire model will differ and driving habits matter too.
I was wondering about this too so I called BFG and TireRack (where i bought my wheels)
Heres what i found:
+ BFG recommended 35psi for both my 275/35/18's and 295/35/18
+ TireRack said that it was ok to look on the side of my door for the manufacturers recommended PSI, i havent had a chance to look yet.
I also asked the TireRack guy if rim width changed the recommended PSI and he said no. ( i have 9.5 front 10.5 rear)
Hope this helps.
Heres what i found:
Hope this helps.
