Car Vibrates After New Setup.Help!
Old May 19, 2007 | 08:03 AM
02BEAST's Avatar
Default Car Vibrates After New Setup.Help!
Guys I just got 18x9,18x10 Rebels with 275 and 295 KDW's they came mounted and balanced to my door.My ? is when I hit 70 mph the car starts to vibrate not terribly though do you think they need to be rebalanced again any suggestions would be appreciated.
Old May 19, 2007 | 09:16 AM
potentialdngr's Avatar
i would say just have them re-balanced, that is a good chance that is the problem
Old May 19, 2007 | 09:51 AM
aznspeed's Avatar
I had this trouble so the tire place "road force tested" the whole set and found out that I had a defective rim.
Ask them if they did a road force test, if not, that should pin point the problem with 100% accuracy.
Old May 19, 2007 | 12:35 PM
rk_2000_Z/28's Avatar
My first thought is the balance...but aznspeed has a good point...might want to get that checked out.
Old May 19, 2007 | 06:02 PM
casey02ws6's Avatar
You need hubcentric adapters on Rebels I am pretty sure.
That is why I did not go with them.
Old May 19, 2007 | 06:57 PM
02BEAST's Avatar
Where can I get them?
Old May 19, 2007 | 07:35 PM
Dip Stick's Avatar
what are they ?
Old May 20, 2007 | 01:49 PM
aznspeed's Avatar
I dont think they have hubcentric? Arent those wheels centered by the studs, not the hub? If I were you, just pay the extra $$ and have them road force tested and that should tell the tech where the problem lies.
Old May 20, 2007 | 06:12 PM
02BEAST's Avatar
So get them road force tested first before I do anything else If I do need the rings where do I find them,Also guys who have the rebels told me when they put on the rings all problems were solved no shaking or vibrating.But I'll get them road force tested first and see.Thanks
