Centerline Dagger wheels on an F-Body?
i tried searching the gallery, and performed a search for the name of the wheels, but came up empty.....has anyone ever see an F-Body and/or have any pics of one (or more than one) with a set of these wheels on it? they are Centerline Wheels Sundance Daggers. i think these look badass, and think they would look great on an F-Body.....
any chance someone could photo-chop these onto a red LS1-style Z28?
Specs:
Rim Diameter (in): 17 in.
Rim Width (in): 9.50 in.
Backspacing (in): 7.000 in.
Offset (mm): +44.00mm
Wheel Material: Aluminum
Wheel Finish: Polished
Wheel Construction: 2-piece
Beadlock Included: No
Beadlock Functional: No
Lug Nut Seat Style: Conical seat - 60 degree
Lug Nut Shank Diameter (in): in.
Washer Outside Diameter (in): in.
Hub Centric: No
Center Bore Diameter (in): 3.187 in.
Center Cap Included: Yes
Load Rating (lbs): 1,999 lbs.
Valve Stems Included: No
Quantity: Sold individually.
Notes: Maximum tire diameter is 33 inches.
Specs:
Hub Centric: No
![](http://mysite.verizon.net/res0kd2j/clw_sundance_daggers.jpg)
