Cutting my tires to hell, need to roll a bit? plz help
alright it wasnt bad before but now its aweful, im getting deep cuts in my tires, and need to take care of it now.
there is 2 spots on my fender that are rubbing \ cutting the tire, 1 towards the front and one at the back, about a 4" section.
now, i dont wanna roll it right up, just need about 1\4 of an inch and to take the sharp edge out.
should i
a) use a bat and just roll it on the well applying pressure on the spot thats rubbing.
or
b) just grind out the sharp peice with a dremel, then apply some paint to prevent rust.
or
c) just take a plastic hammer and some wood and just try to pound it up a hair?
or is there another option that i can do right away?
should i
or
or
the "correct" way is to get a fender roller. but on my prev z. I did the "bat" method for a temporary fix. It didnt roll it up much and it seemed like it rippled my fender a tad. a couple months later I rolled my fenders. If I had to do it all over again. I would have used the fender roller in the first place.
