View Poll Results: Like the rims
I like them
80
66.12%
I do NOT like them
13
10.74%
Meh, they are OK
28
23.14%
Voters: 121. You may not vote on this poll
C6 Z06 rims on a TA
I gotta' get me some!
Originally Posted by CAMAROZ28SS
Those look ******* sweet
What size / offset are they? Did you have to use spacers?
(Add the normal amount of repeadative wheel / tire noobie questions here)
[Oh, and yes, I did read all the wheel / tire stickies and I' m still confused! So there!]
MIKE
They look good, especially for 17's... (18 w/ shorter sidewall might look good aswell) I was going to order those for my camaro, but turned out they were on backorder for the color I wanted. So I'm getting the C6 wheels with the machined face look.
Originally Posted by great421
Yeah, what he said!
MIKE
MIKE
Wheel Spacer Theory 101 (???)
Originally Posted by skeels
I wanna say they are +58, but with me just waking up i cant remember. As said before 275/40/17s all the way around. I did not use spacers yet, i proboly will pick up some becuase they were a pretty tight fit.
OK, so the inside of the tire (but not the wheel) is almost rubbing the inside wheelwell, so because the rims are not available with less postive offset (i.e. - 40 mm vs 58mm), a spacer must be placed on the wheel studs in-between the the brakes and the Vette wheels - Is that correct or am I off?
[Given that my above statement is correct; if those wheel were available with less positive offset, then no spacer would be required - right?]
Let me know! (I only want to buy MY expensive rims once!)
Thanks!
Again - They look great and I gotta' get me some!
(BTW - how wide are they?)
MIKE
#33
MIKE
MIKE
#37
TomZwheels / NC???
[QUOTE=skeels]I got mine from TomZwheels and their support helped out. [QUOTE]
Skeels -
I just moved to NC (Kernersville actually); is "TomZwheels" in NC or are they an online shop (I guess probably not if they stayed open to mount your wheels and tires!)?
MIKE
Skeels -
MIKE
#38
Na, TomZwheels is an online shop located in Texas i belive. They are a sponsor here and had a sale when i purchased mine, it may have been for only May though. Came with everything needed, centercaps, lugnuts, and stems. Shipping was pretty cheap and they got here in about a week if i remember right. Alot cheaper then buying them from the Chevy dealership, even with them not being on sale. I just got them mounted at a local Firestone since they are the only place that stays open past 5pm and had a buddy that worked there mount them while the manager was bitching about closing up shop, but free mounting and balance for the win.
#40
As skeels said the fronts were close (but still clear ok) and the rears cleared plenty.....just for looks i would go with some spacers though. They are set in the wheelwell a tad and would be absolutley perfect with some spacers to make them flush with the body of the car. If skeels can find his reciept it might say the offset on them or he can give you a part number to give to tomzwheels and they could tell you.
<--- the guy who got hell for making the shop stay late as ****..lol.
