Water in the tires...
What can this do and how do I get it out?
Seriously, just find a place that has a better air compressor, and try to drain your tires while hot, then refill them. That should help a bit. If the tires are sloshing, though, you may want to just go to a tire shop.
There's also the ghetto method - poke a hole in your tire tread, drain the water, then patch the hole!
Can the water corrode my wheels from the inside?
