Studs + Lugs for Draglites 90 series? Please help!
What ARP stud lenght do I need to fit these to my car, and what Open end long shanked lugs do I need also. I need these for the front and back. I want to make sure I get the right ones from Jeg`s when I order. Please help! Thanks.
i just went to auto zone and picked up some extesion acorn nuts. not sure the # but they looked like they would work.
Havent tested them to see if they fit either
i plan to get longer studs when i get my rear end next year.
when you call jegs they should know, but the size/length of your shank lug i think wouldn't depend on the size of the studds that you order
Formerly 4mulaJoe
I've been through the exact ordeal. Call Competition Sales here in Houston. They the lugs and washers u need. Couldn't find them anywhere else. For the wheel studs you want some 3" length ones in the front and rear to be NHRA legal. I have 2.5" studs up front with a 5/16" spacer on 15x3.5's. The studs come flush with the wheels and do not stick out like the NHRA requires. The 3" rear stick out plenty.
