new studs for skinnies?
Old Jun 5, 2007 | 09:04 PM
ski23's Avatar
Default new studs for skinnies?
hey guys, sorry for another skinny what to do post, but search is down for me again.just got a set of jegs sportstar skinnies. i just put new pads and drilled/slotted rotors on about 2 months ago. no way the skinnies will fit without spacer. barely fit with a 5/16 spacer but, they do clear. what would be my best option
1) run the 5/16 spacer with the stock acorn lugs. they grab a few threads but....
2) buy the shank style acorn lugnuts w/longer studs and run the 5/16 spacer
3) grind the **** out of the caliper and run no spacer (if possible)
4) grind the caliper some and run a thinner spacer?
anyone else run into same problem? what way did you decide to? any tips,info would be great.
Old Jun 5, 2007 | 10:17 PM
jermzz's Avatar
I dont like the idea of grinding the fronts. Less pad makes for hotter breaks which can lead to either cracking (really bad) or fade. I run a 5/16 spacer with a longer stud. If you need studs, I have an extra set of ARP 12mm x 1.5 (our size) but are the correct length for weld type rims in the front. They're brand new, i'll ship em out to you for 20 bucks.
good luck either way.
Old Jun 6, 2007 | 08:48 PM
ski23's Avatar
ill keep you in mind. still waiting for MT sportsmans so im not sure what im gonna do yet. anymore suggestions?
Old Jun 6, 2007 | 09:23 PM
xpndbl3's Avatar
get the ARP ones that are 3.25" long and call it a day, my buddy snapped off 3 studs on his front skinnies while we were driving down the road, felt like a flat tire. Not worth risking it on the stock studs IMO.
Old Jun 7, 2007 | 04:09 PM
ski23's Avatar
if i go with these studs will i still be able to mount up my zr-1`s with no troubles?
Old May 3, 2008 | 12:32 PM
Vetal's Avatar
I've got the same question
Old May 3, 2008 | 12:34 PM
Vetal's Avatar
but thinking about it, I guess they won't fit cause nuts will stuck on the stud long before securing the ZR-1...
Old May 3, 2008 | 03:30 PM
chrysler kid's Avatar
i dont think you can get the brakes hot enough to crack them , if you get to that point your driving way too hard with skinny tires up front to begin with
Old May 3, 2008 | 04:48 PM
99FormulaM6's Avatar
you need open ended lugs with extended studs
Old May 3, 2008 | 08:42 PM
02Z28LS1's Avatar
i absolutely loathe the idea of having to grind on the calipers to get a wheel to fit, so my vote is to get longer studs and use the spacer.
Old May 5, 2008 | 11:13 AM
1CAMWNDR's Avatar
Longer studs +spacer +open ended nuts.
Old May 5, 2008 | 11:23 AM
Camaro396's Avatar
Someone on here, I believe it was Matt D, wrecked a car because a grinded calipar came apart.
Old May 5, 2008 | 12:14 PM
Vetal's Avatar
99FormulaM6: thanks!
Old Jun 10, 2008 | 02:47 AM
Vetal's Avatar
Please someone explain what is "shank" and what is "acorn" lug nut?
Is that correct that for "ZR1-style" I need acorn, and for Weld Pro stars I need "shank"?
Old Jun 10, 2008 | 08:23 AM
ndfrsd6's Avatar
the shank goes inside the wheel (weld) the acorn is the normal lug you find on corvette's shanks and acorns come opened ended and closed for long studs or reg length .....you can get slightly longer studs up front and a spacer and you will be fine no grinding needed
Old Jun 23, 2008 | 01:06 PM
Vetal's Avatar
Will these acorn style nuts be OK?
http://store.summitracing.com/partde...5&autoview=sku
