Convo Pros on T/A...Help
Old Jun 13, 2007 | 08:39 AM
DYING BREED's Avatar
Question Convo Pros on T/A...Help
OK, Ive heard convo pro's bolt up on an fbod w/o mods, but i picked up a 15x4 brand new from a friend and it just hits the caliper.... should i run small spacers and change out to ARP bolts??? and which rear wheel fits w/o mods???? I really want these on my car and i need to know which one fits... thanks ppl
Old Jun 13, 2007 | 08:49 AM
its supposed to fit the car, but i dont have the correct pro mag lug nuts for it.... maybe it will sit correctly on the wheel if i put it on with the lug nuts....
Old Jun 13, 2007 | 09:16 AM
LS69TA's Avatar
Yea, try the right lug nuts. The most you should have to do is lightly touch up the caliper with a grinder.
Old Jun 13, 2007 | 09:36 AM
tim99ws6's Avatar
Mine fit perfectly with no grinding. You have to run the correct lug nuts. Not only does it look stupid, it's a major safety issue.
I got mine from Jegs. Also, make sure you get the washers with the lugnuts.
Old Jun 13, 2007 | 09:41 AM
kool, use the lugs recommended in jegs???
Old Jun 13, 2007 | 02:30 PM
LS69TA's Avatar
They're the shank style lugnuts. I know the part #'s have been posted on here but I can't remember them.
Old Jun 13, 2007 | 02:50 PM
BADD SS's Avatar
Mine fit perfectly, you MUST use Pro Mag lug nuts with washers. That is definately not safe to use an acorn nut, its not made for it.... Most Likely the cause of your rubbing, the wheel is off center.
Old Jun 13, 2007 | 04:23 PM
tim99ws6's Avatar
Yes, use the lugs that Jegs recommends.
Old Jun 14, 2007 | 11:00 AM
cool, thanks, anyone have any pics of a t/a with them???
Old Jun 14, 2007 | 01:18 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
There was that huge thread in here a while ago where JNorris and PSJ contacted centerline to make wheels that fit. They ended up with the 15 x 9 / 6.5 bs wheel. They said it required some grinding, but not much.
Here's some pics of them on a white Camaro:
http://www.wheels.ls1tech.com/galler...=184&g2_page=2
