weld 15'' pro star wheels ??
Old May 8, 2003 | 05:48 AM
oOoLy's Avatar
Default weld 15'' pro star wheels ??
What Bolt Circle, Bolt Circle,ARP stud lenght, Spacers and lug nuts do i need to fit these to my car.
I need these for the front and back.
Thanks
Adnan
Old May 8, 2003 | 08:46 AM
BIGBOS's Avatar
Default Re: weld 15'' pro star wheels ??
I ordered mine from billingsley racing...
15x10 in the back w/7.5" back spacing
15x3.5 in the front w/1.75" back spacing I believe
I'm running ARP studs in the back, not the extra long ones, but the middle length, longer than stock of course, forgot the measurements on those too, they are listed on ls1speed.com website though
I'm running open ended lug nuts, who ever you order from will usually reccomend lugs...
If you do get 15x10's in the back your going to have to spend quite a bit of time grinding the caliper, I finally got mine to fit w/a 5/16's spacer...
I'm also running the 5/16 spacer in the front, no grinding needed in the front at all...
Old May 8, 2003 | 09:02 AM
oOoLy's Avatar
Thank you BIGBOS for your reply ... do you have some pics plz ...
