heating drag radials
Old May 8, 2003 | 08:35 AM
Fast Eddie's 02 T/A vert.'s Avatar
Default heating drag radials
I need some help guys.I'm getting a set of drag radials.Do you have to heat them up before you race.I've heard conflicting stories.Some guy runnin slicks at the strip told me you don't have to heat up drag radials.He said you only heat up slicks
Please advise.
Old May 8, 2003 | 08:55 AM
Patman's Avatar
Default Re: heating drag radials
You definitely should heat up the drag radials, although they don't need to be spun as long as slicks though. A good 5-10 second burnout is more than enough. That's all I used to do when I ran BFG DRs.
With a pure slick though, they need a nice smokey burnout to make the rubber softer. If you ever feel a cold slick it's not really super sticky. A good 10-15 second burnout is needed with them.
With a regular radial, you don't need to heat them up at all, they won't get any softer, but you should still do a quick 5 second burnout just to clean them off if there is any dirt on them from the staging lanes, plus to make sure you get any water off them before going up to the starting line.
Old May 8, 2003 | 11:27 AM
Thanks Patman,
I noticed the BFG DRs cost a little more than the Nittos.Are the BFGs a little better do you think?
Old May 8, 2003 | 11:32 AM
Patman's Avatar
The BFGs definitely will give you better 60fts at the track, but for street driving, the Nittos last much longer and are safer in the rain.
Old May 8, 2003 | 12:32 PM
Thanks Patman,
You've helped me a great deal.I'm going to get the BFGs and only put them on when i race.
Old May 10, 2003 | 08:28 AM
toxic99's Avatar
actually, if you do a nice 2 minute burnout on regular radials, they will get nice and hot and sticky
Old May 10, 2003 | 06:34 PM
unit213's Avatar
Administrator
Maybe, but you still won't do better than a 1.9x 60'.
Patman is like Bo. He knows oils, tires, MAF, etc. "Patman Knows".
Old May 11, 2003 | 05:06 PM
niphilli's Avatar
You can do a bit better than a 1.9X on DRs. I have a buddy that has cut 1.90x's on pure street tires. If you heat up the DRs enough they have 1.7x's in them. I would not reccomend this on a stock rear, but it can be done.
-Nick
Old May 11, 2003 | 06:36 PM
Patman's Avatar
Nick, I think he meant you can't do much better than 1.9 on street radials. That's pretty much true, it's very rare to see someone cut a 1.89 or better on regular radials. It's not impossible, but definitely not something that happens every day.
Old May 13, 2003 | 10:50 AM
niphilli's Avatar
Doh~! cant read
Old May 13, 2003 | 06:23 PM
unit213's Avatar
Administrator
Way to have my back! <high 5's Patman>
