fixing curb rash?
chrome , polished or painted aluminum ?
If painted aluminum I'd set them up on a lathe or just use the axle to spin them, file and sand them smooth (block of wood and sandpaper) and strip the rest of the clearcoat (if cleared) and polish the entire rim....
Is it worse than just cosmetic ?? If the rim is bent I'd get rid of it...
The Z06 design is a bit%h to polish all the way, repro rims are like $195 a piece.... a shop is likely going to charge $200 or so to fix what you got... not sure what I'd do but I think I'd buy two new rims and sell the scratched rims on E-stink....
OR... por guys solution: use the rear axle as the drive ... set rear on jackstands, remove tires and valve... mount rims, polish the dish while spinning in 1st gear... be careful not to get your fingers between the spokes..... this is dangerous....
here's a pic of one of my Borbet "T" rims that I stripped and hand polished myself:
Shot with Canon PowerShot A630 at 2007-06-29
also there is fn bend in it, its on the inside of the rim though, think this will be a problem?
There are companies that straighten rims but with shipping it's probably as expensive to just buy a new rim...
well... if you never exceed 50mph you're safe I guess..... ... seriously, I don't mean to sound funny here but you can damage a whole lot of stuff if a rim or tire goes....
OK... this is not a simple curb rash. Have a look at the pic below, it looks like the entire rim is bent, not only the outer edge... correct me if I'm wrong...
Go to a tire shop and have it balanced... let's see what they say with the tire mounted... I think it's a waste of money but ok....
If you don't have the money for another (used) rim then don't take a chance drivin with the damaged rim.... you might need a lot more money to fix the damage this junk wheel caused.... what about your wheel bearing ? That's not too cheap either .... just something else to think about ...
you just got these rims in the mail ?? I'd tell the seller to expect a credit card dispute or attorney's fees after you seeking legal advice if he doesn't want to make this right....
