Will these tuck? weld 15x10, 7.5 bs
I have an 01 SS, about to put on some weld draglites thats are 15x10 with a 7.5 backspacing. Just wanting to know if they will tuck, and with what tire should i run with them, it a cam only car with 4:11 gears.....Really want something that will work good with my setup , tuck, not have to modify anything outside of grinding the calipers.
Location: Your girl's back door giving her the long stroke while you're at work
You will have to grind the calipers unless you run a spacer on the rear. But if you are down with grinding then yes they will fit
That is what I am running with a 275/50/15 M/T Drag Radial.
Pics here.
https://ls1tech.com/forums/appearance-detailing/741068-new-pissed-off-look.html
Pics here.
