URGENT Tire Size question
If I run a 36mm offset on my 17x9 wheel all four corners, what tire am i safe using w/o rubbing??? 2001 T/A stock height.
wheels are crager SS
Originally Posted by TUFAS4U
even with the 36mm offset?? wont that stick way out?
Now if you are lowered the rear axle will need to be centered to avoid contacting the wheel well lip, and the front tire, may ever so slightly rub the black plastic wheel well liner at full tun, but that is no problem.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
