Will OE 18X10.5 C5 Wheels fit my 98 Z28?
My cousin has offered me a set of his OE C5 wheels. He said they're 18X10.5 in the rear. I'm wondering if they'll fit my 98 Z28. BFH mod? Spacer? Any help is appreciated.
I run the same wheel in the rear with 295/35/18's. I believe they have a 65mm positive offset. I ran them with no spacers and they didn't rub, but were tucked in too far, so I added a 5/16" spacer.
From: Your girl's back door giving her the long stroke while you're at work
They don't need cut and you don't need spacers.
Look at the link below and you'll see where he hammered to fit 315s. So you want to massage the same area
http://www.jodyshapiro.com//z28/315s/images/well-1.jpg
There are some good pictures here also. He also grinded off some of the bumpstop which you shouldn't have to do
http://www.bfranker.badz28.com/96SS/11inchZR1.htm
I just installed some C5 Z06 wheels on my '99 Z28 and they would not fit without a spacer. They are factory wheels and they have 295/35's on them. They rubbed the bump stop on the inside .
Originally Posted by jrgswhitels1
Those wheels will have a large offset at about 80mm. Stock for 4th. gens. are 50mm!! You will need some kind of spacer of some sort!! Sorry>
