How To make this Wheels fit ,,,,,,,
Old Jul 9, 2007 | 08:52 AM
camaro_best's Avatar
Default How To make this Wheels fit ,,,,,,,
after 1week I'll order 2 new rear Wheels ProStar
some search how to install the wheels and find
1- The rear calipers need grinding regardless of spacer use.
Do I Need something other Grind the rear clipper to make the wheels fit?
and what is the best size wheels for my Z
the Size 15X10 BB 7.5 with 275 / 60 / 15
or 15X10 BB 5.5 with 275 / 60 / 15
the Z
drag race / street race / cam-only with T/C 3500 2.5STR
Old Jul 9, 2007 | 01:45 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
This is the size you want. If search is working just dig around and you'll find pics and a how to for the Welds. Maybe some of the other guys have the links saved
Old Jul 10, 2007 | 01:14 AM
LT1's Avatar
LT1
correct size for camaro with 15X10 weld pro star is 7.5 BS (if your running stock 10 bolt)
max tire you can fit in the rear is 325/50 - 15's with some modifications done.
if you do this remember to get stronger and longer lug stud's with or without spacer. its a must with these wheels. stock studs break easy
