295 Tires...Will they rub?
Old Jul 28, 2007 | 11:56 PM
95Firehawk's Avatar
Default 295 Tires...Will they rub?
I just got 295/35/18 BFG DR's for 18 x 9.5 Z06 wheels. I am wondering if these will rub or hit my bump stop at all, and if the BFH is needed. My car is not lowered either. But right now the car is on jack stands waiting for the wheels and tires to be mounted and i just put the rim right on the hub tonight to get an idea and it seemed to only be about a centimeter from the inside lip hitting the bump stop. Any info appreciated...
Old Jul 29, 2007 | 12:21 AM
Blakbird24's Avatar
Restricted User
What offset? If it's higher than 58mm, it's going to be damn close. Lower than 58mm, you should be just fine. From your comment about the bump stop, i'm guessing they are a pretty high offset.
Old Jul 29, 2007 | 12:29 AM
95Firehawk's Avatar
Offset is 53mm. So I shouldn't need to do anything at all they should just bolt right on safely? Also do you get wheel hop with 18s?
Old Jul 29, 2007 | 11:43 AM
Blakbird24's Avatar
Restricted User
Yeah they SHOULD work. I had 58mm Z06's with 275's and I could have gone to 295's with no problems, so I would think you will be just fine.
I had zero wheel hop, even when my suspension was stock.
Old Jul 29, 2007 | 12:25 PM
95Firehawk's Avatar
Ok, thanks blackbird. I'll post some pics tomorrow when they are on the car!! I still have yet to see a red LT1 formy with chrome z06's.
Old Jul 29, 2007 | 03:08 PM
Screamin_Z's Avatar
I recently had 295 BFG DRs on my car with TomzWheels 18x10.5 w/ hotchkis springs and it SLIGHTLY rubbed on the wheel well. it wouldn't take much at all to push that area back a lil and have no issues. I didn't roll my fenders and was worried about that but I had NO ISSUES with the finder lips.
Old Jul 29, 2007 | 03:13 PM
bene's Avatar
Trunion King
I have 53 mm offset 10.5"x 18" Z06 wheels wrapped w/ 295s BFGs and they don't rub.
Old Jul 29, 2007 | 03:15 PM
1BadTA13's Avatar
i have 295/35/18's on the back of mine and they fit no problem.....
Old Jul 30, 2007 | 02:03 PM
JWG01LS1's Avatar
I'm running 295's rear on 18X10.5 wheel, They fit fine, but ive noticed some very light rubbing marks in the wheel well. Tires are not affected at all though!
Old Jul 30, 2007 | 06:41 PM
SS1156's Avatar
Where did you guys get the 53mm offset wheels? I'm looking to go up to 18's
Old Jul 30, 2007 | 06:57 PM
gallardo259's Avatar
Is the size of the wheel well the same on all f-bodys? lt1/ ls1 camaro/ firebird
Old Jul 30, 2007 | 07:38 PM
bene's Avatar
Trunion King
I got mine from one of our sponsor here, LMPerformance.
Old Jul 30, 2007 | 10:28 PM
Xsta Z 28's Avatar
295's DO NOT ift on 9.5" wide wheels . . . .
Old Aug 1, 2007 | 01:16 AM
rocket22's Avatar
I have 18x10 TT2's and had to roll the lips.
Old Aug 1, 2007 | 07:52 PM
95Firehawk's Avatar
xsta Z28...Yes they do. I had a certified worker do them for me who used to work at a very respected high performance shop and they are perfectly fine! He even showed me his little chart...
Old Aug 2, 2007 | 08:26 AM
Xsta Z 28's Avatar
Thumbs down
"certified worker" . . . what ever . . . . Anybody can stuff too big a tire onto too small of rim. I bet he also approves a 315/35ZR17 on a 9" wheel . . . .
There is not ONE tire manufacturer that would "recommend" a 295/35ZR18 tire onto a 9.5" wide wheel . . . PERIOD. Do you think I pull this stuff out of my butt?
A square peg fits in a round hole too, if you hit it hard enough . . .
Old Aug 2, 2007 | 12:13 PM
cowboysfan's Avatar
check it out!!!!!
M/T has it listed on thier web site. 295/45/17, rim width 9.5-11.0 and 295/50/16, rim width 8.0-10.0 . plus I'm running 295/45/17 installed by tire-discount who said they would not fit. once I told them M/T had them listed on thier web site and they checked, tire-discount said "OK we can Do it". so it can be done............
Old Aug 2, 2007 | 01:10 PM
Xsta Z 28's Avatar
A 295/45 series tire on a 17" diameter wheel is totally different that a 295/35ZR18 . . .
Thus why I expanded my explanation in the 16th post . . . .
Old Aug 2, 2007 | 05:21 PM
02silvaZ's Avatar
best analogy in awhile
Old Aug 3, 2007 | 07:03 AM
ws6pewter's Avatar
just like Xsta said, it has alot to due with the side wall height. Just like I can run 315-60-18 on a 9" rim on my truck with no problems. But on my T/A I have a BFG 295-35-18 on a 10" wheel and it fits perfect. The tire does not bulge out nor does it look stretched on the rim.
As to fitment, I'm running the 295 on the AR Rebel 18 x 10 with 41mm offset in the rear and so far I have no rubbing. My car is not lowered and looks like I might have to roll the fender when I get new springs.
