patch or plug
Old Aug 6, 2007 | 06:44 AM
ws6pewter's Avatar
Default patch or plug
Patch or plug a nail hole in the tread on BFG KDW NT? I all of my truck tires they have always been plugged but I don't know what's best for a perfomance tire.
Thanks
Old Aug 6, 2007 | 11:45 AM
DopeFedZ's Avatar
I always try to get a patch installed whenever possible.
Old Aug 6, 2007 | 12:28 PM
BanditTA's Avatar
Patch, plug is only a temp fix technically.
Old Aug 6, 2007 | 12:36 PM
ws6pewter's Avatar
Why is it a temp fix? I have run 50,000 miles on plugged truck tires without problems. This is just the first time I've stuck anything in a performace tire. The tire less than 500 miles on it and the nail is stuck in almost centered in the tread.
I was thinking patch might be better than plugging it due to possiblity of run high speeds and slinging the plug out.
Thanks guys
Old Aug 6, 2007 | 01:12 PM
Greggy's Avatar
I've always plugged my tires. Never a problem. I even had to put two plug in one hole in order to seal it...still no problems. I know tire shops don't like this and some will say it's not safe, but I have done it 20+ times without issue so far.
Old Aug 6, 2007 | 01:15 PM
Greggy's Avatar
The plug will not "sling out". The theory is that after a puncture the belt structure could be damaged in such a way that the tire itself could fly apart.
Never plug or patch a tire with side wall damage... although I've done it on the edge of the tread.
