Drag strip worthy tires?
Alright, I've got a pair of Sumitomo HTR40Z P275/40ZR17 on the rear, do you think that they would be good on the track?
I've heard not to go through the water box with these tires, what do you think? And also should I lower the tire pressure and to what PSI?
thanks for your feedback.
Nick
Nick
i would say shure you can go to the track with them just don't expect them to give you great times. I think my 275 fuzions grip better in the holeshot then my 315 sumitomo's
Location: Your girl's back door giving her the long stroke while you're at work
Get some drag radials if you want some good 60 ft times. You don't need a huge burnout with street tires. Drive around the water box and spin them just enough to get a little smoke (basically just enough to clean the debris off) and head for the lights
roll through the water box and spin the tires after the box to get the water off. nitto's extreme 555's are great track and street tires, and dont have the wear of drag radials.
18-25 is what i would start with experiment but you'll have to fill them back up after obviously. i usually go to the track with my fuzions on the rear and go around the box and back into it lightem up till i feel a little bite and let off and you hear that nice chirp as they grab on the sticky pavement.
Like stated above, on street tires STAY OUT OF THE WATER and just turn 'em over enough to clean them.
