LT1 Brakes
Old Aug 19, 2007 | 11:35 PM
blueeyeddevil141's Avatar
Default LT1 Brakes
I asked this before. Will a set of Prostars clear a set of LT1 brakes? I can trade my brakes for LT1 brakes....and I really want ProStars haha.
Old Aug 19, 2007 | 11:41 PM
sixvi6-camaro's Avatar
Nope you will still have to grind.. it will just take less grinding to get the job done.
Old Aug 19, 2007 | 11:47 PM
Like....about how much grinding will I have to do(fronts or back, or both?)
Anyone use the Jegs Pro Star knock offs? How's the fitment?
Old Aug 20, 2007 | 12:43 AM
phantomLT1's Avatar
Default I did not have to grind mine too much.
I am also using a 1/2 ' spacer though
Old Aug 20, 2007 | 03:22 AM
chevynut50's Avatar
I have 97 LT1 camaro with Weld Draglites. Used a 5/16 spacer on the front with no grinding, however the back will require a minimun amount. Mainly the finned portion along the top outer edge of the brake rotor. You'll also need longer wheel studs if using the Weld wheels.
