Wheel and Tire Fitment Question for the Experts...
LS1Tech Administrator
Received 1,756 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Lately I’ve been considering a change of wheels for my Camaro. I still love the ZR1 look for F-bodies, and very well may decide to keep them, but after a couple years of having it I’m just giving some thought to other wheel options.
Anyway, I’m considering the following wheel & tire package and just wondering what the experts on fitment here think about this. I’ve looked over the FAQ sticky in this section, but what I’m trying to do is a little different than the standard size combos listed. Here are the specs:
Front:
18 x 8.5 wheel, with a 35mm offset
255/40/18 tire
Rear:
18 x 10 wheel, with a 41mm offset
295/35/18 tire
Now for my questions:
- Will this fit without fender lip rolling or a BFH to the inner wheel well? I’d rather not do either of these body mods on this car. I have stock springs, but they have sagged a bit over the last 9 years so the car sits just a little lower than stock.
- Will the 10” wide rear wheel with a 41mm offset stick out too far for the Camaro body lines? Will it look “wrong”.
- What about the front? Is a 35mm offset going to make an 8.5” wheel stick out too far up front, or would that be similar to my current 9” wheel with a 50mm offset?
Thanks for any help/advice.
Front:
255/40/18 tire
Rear:
295/35/18 tire
Fitments should be fine. I run 38 mm offset 9.5's front and 38 mm 10.5's rear.
The front wheel will sit nicely in the wheel well, it will move outwards just a touch but will not stick out.
The rear, your combo moved inwards 3 mm compared to mine and your wheel will be 1/4" narrower each side, so rubbing with stock supension should not be an issue. It will not sitck out of the wheel well.
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Thanks.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
