Tire Help
Old Sep 2, 2007 | 12:28 AM
Artic01SS's Avatar
Question Tire Help
Sorry for this question, I just cant find a def answer in any other link. I have an 01SS and just bought a set of Rep C6 rims. They are 18 x 8.5 and 18 x 9.5 with a 56mm offset. I bought em just becuase the price couldnt be beat but I really have no idea what i got into. First off what size tires should i get for the front and back (probably goin with nitto 555) but i have no idea what demensions to get. Also I dont know if im going to need any kind of spacer. I just want the car to look normal without having to do anything crazy. The stock springs set up with the GM 17" 10 spokes already looks like im riding a dune buggy, now when i get the new rims on is it going to make that worse better or the same. Cause if it gets any worse I'll probably lower it when i do the tires and if I do have to lower it, by how much. Thanks for the help and sorry again for what im sure is a repetitive question.
Old Sep 2, 2007 | 10:25 AM
Artic01SS's Avatar
Old Sep 2, 2007 | 11:39 AM
staringback05's Avatar
you might need a spacer but weirdly enough alot of the cars are different....for example i have 17x9.5s on the front and they slightly rub but on my friends...they dont touch at all..
you could go with a 245 and 275 respectively
Old Sep 2, 2007 | 12:05 PM
Artic01SS's Avatar
Also Id probably be lookin to get a slightly wider tire on front and back just to give a little protection to the rims. Could I get away with 275's on the 8.5 and something like 289/295 on the 9.5s also im a bit confused on the sidewalls. Is it the fronts 40 side wall and the rear with 35s?? Thanks
Old Sep 2, 2007 | 12:30 PM
the 275 on the rear will protect it, since its 9.5 i never have scratched mine its, that 245 would be ok on the front to...you want to keep that front size down somewhat
Old Sep 2, 2007 | 01:01 PM
Switchblade's Avatar
Front's using the 18x8.5 wheel I'd go with a 245-255 tire.
Rears using the 18x9.5 wheel I'd go with a 275-295 tire.
Old Sep 2, 2007 | 02:18 PM
wabmorgan's Avatar
Better watch the aspect ratios. Make sure your tires have about the same overall diameter or it will drive your ABS crazy.
Old Sep 3, 2007 | 08:14 AM
Artic01SS's Avatar
thanks for the help, no i just need to know what size sidewalls to go with and if im going to need a spacer anywhere
Old Sep 3, 2007 | 03:12 PM
Artic01SS's Avatar
ttt..
Old Sep 3, 2007 | 08:59 PM
Doc99SS's Avatar
You want to stay around 25.7 to 26.2" in tire diameter. I have a '99 SS, the 275/40R17s are 25.7" in OD. For the front 18x8.5 wheels, I would run P255/40R18s, they are 26.02" in OD according to my Tire & Rim book. For the rear 18x9.5" wheels, I would run P295/35R18s, they are 26.10" in OD. These tire sizes would fill up the wheel wells a bit more than the factory tires.
