M/T et street radials 305/35/18!!!!! they are here
Originally Posted by SVC707
im launching at 4500 popping the clutch and its still not high enough. still bogs down a tad. so ill have to say its got grip.
well my dyno is on a dynopack so you can prolly take off what 30 from my numbers. everyone wants to argue that, but thats another topic. the track is infineon raceway. so usually always prepped good. let me find my vids and i can explain the launch
http://www.youtube.com/watch?v=mOWZIU6oFV8
i realized 1st gear was no good for doing my burn outs. after i missed a shift i was babying the car to make sure it was ok. but you can see the last two runs i almost floored if off the line and somewhat floored it down the track. with these sticky tires in the rear its not good to run 275/40/17's up front and no sway bar on a windy *** day!!!!!
the last run i floored it @ 4500 and popped the clutch, still a slight bog so next time i go ima try and launch closer to 5000 btw tire psi was at 24? forgot already
my suspension is not setup for drag btw. i have gc coilovers 600/150 springs rates with bilstein shocks
i got them from mccormack racing, i dont want to post a price as i dont know what they normally sell them for.
mike: all i can say is they hook. if you look, mightymouse uses these same tires in 315-35-17 and is pulling 9's.... you make the call
#33
Keep in mind that tread ratings are only good within a single manufacturer's line of tires.
Treadwear ratings are NOT an industry wide standard!
200 on a Toyo is not a 200 on a Goodyear or MT. FYI.
#34
you could probably get it to fit. i got the 315's to fit my stock 9.5" wheels (even though they're 17's) and even though i don't condone it, theyre not too wobbly on the street.
