RUFF 9,5" WILL IT FITT?
Old Sep 24, 2007 | 02:42 AM
WS6Stefan's Avatar
Default Ruff 9,5" Will It Fitt?
Thinking of Ruff 278 or 280 to my Hawk
Car Firehawk 2002 (Trans Am) Silver
Wheels Crome
Will 9,5x18" fitt in front?
Or must i have 8,5x18" Front and 9,5x18" Back
ET?
OR
Will 9,5x19" fitt in front?
Or must i have 8,5x19" Front and 9,5x19" Back
ET?
Thanks alot Stefan in Sweden
Old Sep 24, 2007 | 04:05 AM
stevensLS1's Avatar
the 9.5's will fit with the correct backspacing.
Old Sep 24, 2007 | 07:14 AM
WS6Stefan's Avatar
18" or 19" ???????
Old Sep 25, 2007 | 12:36 AM
WS6Stefan's Avatar
Any ? Al you with Ruff what size do you have???
Old Sep 25, 2007 | 07:29 AM
No Juice's Avatar
If you do a search on here you will find that the 18x9.5" will NOT fit on the front. They will hit the brake calipers
Old Sep 25, 2007 | 08:21 AM
WS6Stefan's Avatar
If you do a search on here you will find that the 18x9.5" will NOT fit on the front. They will hit the brake calipers.
I have, but i dont know what to think about it!!
Thread1
I am running 18x9.5 with 255/35/18 on the fronts and 19x9.5 with 275/30/19 on the rears
Thread2
I got 9.5 width wheels for all four corners and they did not fit the front.
Old Sep 25, 2007 | 01:49 PM
ezekielta's Avatar
If you go with an 18x9.5 in the front you will need 35mm offset.
If you go with a 19x9.5 in the front you can go 45mm or 35mm offset
On the rears both 19x9.5 and 18.9.5 will work with a 35mm or 45mm offset.
I know all of these from experience as I purchased a pair of 45mm offset 18x9.5s and they will not work on the front. They do not clear the caliper.
Old Sep 25, 2007 | 03:12 PM
ericn99's Avatar
I have RUFF 278's 19x8.5 front and 19x9.5 in the rear and they do not rub at all but the front comes within a 1/16 of a inch from rubbing I think 9.5's in the front would rub. the 8.5's are fine for front man I have 245/35/19's and 275/30/19 on the rear
Old Sep 26, 2007 | 12:47 AM
WS6Stefan's Avatar
ericn99 What ET do you run?
Can you send me som pics?
1transam@gmail.com
Old Sep 26, 2007 | 08:58 AM
ezekielta's Avatar
If you go with a 19x9.5 on the front you would need a 45mm offset to clear with 275/30/19s. I verified this for another person here by placing my rears on the front to test so it will work.
Old Sep 26, 2007 | 01:18 PM
Rickys S/C Z28's Avatar
man i hope i did not do a bad thing!! i JUST orderd a set of 18x9x5 for front and back the folks said they will work. man i hope so!!
Old Sep 26, 2007 | 01:20 PM
No Juice's Avatar
Where did you order from?
Old Sep 26, 2007 | 03:59 PM
WS6Stefan's Avatar
Rikeys S/C Z28 You se man it`s not easy to know!
Stefan
Old Sep 26, 2007 | 04:54 PM
the place is not a sponcer but if you look in the theard on here about were to buy ruffs at it was a place called hubcap tire and wheel the gaentee(sp?) they WILL fit or $$ back. ill see if i can find the link
Old Sep 26, 2007 | 05:20 PM
http://www.hubcap-tire-wheel.com/ruf...ng-r280-b.html
here is the link im going to call and make sure!!!
Old Sep 26, 2007 | 07:52 PM
ezekielta's Avatar
If they are sending you 45mm offsets for the front and rear it will not work on the fronts!!!!
Old Sep 26, 2007 | 07:55 PM
BAN-LS1's Avatar
wrong see sig 9.5 on all 4
Old Sep 26, 2007 | 07:56 PM
BAN-LS1's Avatar
i have a set of 35's and 40s neither have a problem
Old Sep 27, 2007 | 12:05 AM
will ill find what offset they sent me should have the wheels in 6-10 working days
the tires i got are nitto 555s 285/35/18s all 4 man yall got me worred!! i hope they fit cause sending them back from hawaii will suck!!!
Old Sep 27, 2007 | 01:37 AM
RUNINHOT's Avatar
The 35's will fit the front for sure. I have them on my car.
