Help!!!!!!wheels Want Fit
Old Sep 25, 2007 | 08:40 AM
camaroboy869592's Avatar
Default Help!!!!!!wheels Want Fit
I have a 1995 trans am ws6 and i am having a problem with wheels fitting on the back of my car.i have a set of 2002 trans am ws6 wheels and a set of 1999 trans am wheels and both do not fit on the back of my car and they fit fine on the front so if anyone has had this problem please let me know.thanks
Old Sep 25, 2007 | 08:51 AM
99zee's Avatar
If I remember right the wheels have to be ground slightly to fit on the rear. I sold my stock wheels a few years ago to someone with an early 4th gen and they had the same problem. Can't remember what exactly needed to be done, but its not that big a deal to make them fit. I will try to find out what they did.
Old Sep 25, 2007 | 09:31 AM
KEE AUDIO's Avatar
I don't think it's the wheels that need to be ground, I think it was the brake calipers.
Old Sep 25, 2007 | 09:37 AM
fitz98ta's Avatar
on the earlier 4th gen cars the center of the axles appears to be a little bigger. you just have to grind the center of the axle a little bit to get the center of the wheel to slide over it
studderin's Avatar
LT1 cars the hubcentric ring on the axles is like .05mm smalled then LS1 cars. Just grind a little off the rim di.
Old Sep 25, 2007 | 10:05 AM
Thanks Everyone For Your Help !!!!! I Will See What I Can Do.
Old Sep 25, 2007 | 11:20 AM
Thule's Avatar
i once putted the 00 10spokes of my 98 camaro on a 95.. they didn fit at all.. but with a little "man power" i got them on.. but o man tooked me long time to get them off agen
Old Sep 25, 2007 | 11:54 AM
69TA's Avatar
just get small spacers and you should be fine.
Old Sep 25, 2007 | 08:25 PM
JGKadell's Avatar
grind off the small ridge on the inside of the wheel centers, NOT the axle.
Old Sep 25, 2007 | 10:26 PM
mrr23's Avatar
the LT1 rear axle hubs centers are larger than the corvette and LS1 f-bodies. just grind the center out enough to get the wheel to fit over the hub. been there, done it more than once.
Old Sep 26, 2007 | 09:49 AM
Thanks For All Of Yalls Help.
